How can I write the code for a batch fillet plugin for images like this?
Drawing2.dwg
As shown in the figure below:
Select multiple graphics in batch and change the R value from 0.2 to another value?
Code what's that for ?
Join Fillet R 0.4 P pickobject enter
All done
All done
Have to fillet the 3 long arcs segments before joining. But yes no lisp needed for simple task.
The large arc is like the base radius for all the teeth, so changing that may need a complete redraw. behind the shape must be some form of formula, or design rules.
Sounds like a custom gear.lsp is needed.
Edited by BIGAL
Much like Elvis, the OP seems to have left the building.
In case there is a dramatic return, here is a LISP that should work, though unclear what "code" they want or or if this is for an actual plug-in.
Solved: Fillet multiple polyline all at once by lisp - Autodesk Community
I didn't look at Kent Cooper's version to prompt for a radius, but used the original and added something simple to it. I am sure Kent Cooper's is better.
(defun C:FMP_R (/ plss n rad)
  (setq rad (getdist "\nEnter fillet radius: "))
  (if (and rad (> rad 0.0))
      (command "_.fillet" "_radius" rad)
      (if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE"))))
        (repeat (setq n (sslength plss))
          (command "_.fillet" "_polyline"
                   (ssname plss (setq n (1- n))))
Lee Mac has a similar code.
The FMP_R and fpoly codes perform conjugations with a given radius.
Only in these codes it is impossible to set the value radius = 0
Is there a code for interfacing with a radius of 0?
There's also the marko_ribar code, but I couldn't verify it. When loading, the message appears: Unknown command.
Edited by Nikon
Did you bother to check the link I posted?
The first one in my link from Kent Cooper will do fillet>R>0 if that is the value of  FILLETRAD.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/6473166#M130031
The FilletMultiplePolylines will work with 0 radius.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/10151411#M130041
