amook147 Posted Friday at 07:12 AM Posted Friday at 07:12 AM Drawing2.dwg As shown in the figure below: Select multiple graphics in batch and change the R value from 0.2 to another value? Quote
SLW210 Posted Friday at 12:17 PM Posted Friday at 12:17 PM Are you looking for a LISP, Python, VBA, .NET, etc.? I moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote
BIGAL Posted Friday at 11:13 PM Posted Friday at 11:13 PM Code what's that for ? Join Fillet R 0.4 P pickobject enter All done 1 Quote
mhupp Posted Saturday at 12:30 AM Posted Saturday at 12:30 AM 1 hour ago, BIGAL said: Code what's that for ? Join Fillet R 0.4 P pickobject enter All done Have to fillet the 3 long arcs segments before joining. But yes no lisp needed for simple task. Quote
BIGAL Posted Saturday at 02:30 AM Posted Saturday at 02:30 AM (edited) The large arc is like the base radius for all the teeth, so changing that may need a complete redraw. behind the shape must be some form of formula, or design rules. Sounds like a custom gear.lsp is needed. Edited Saturday at 02:30 AM by BIGAL Quote
Tsuky Posted Monday at 04:03 PM Posted Monday at 04:03 PM @amook147 Try this With your exemple seem to work's... mdf_gear.lsp 1 Quote
SLW210 Posted yesterday at 12:01 PM Posted yesterday at 12:01 PM Much like Elvis, the OP seems to have left the building. In case there is a dramatic return, here is a LISP that should work, though unclear what "code" they want or or if this is for an actual plug-in. Solved: Fillet multiple polyline all at once by lisp - Autodesk Community I didn't look at Kent Cooper's version to prompt for a radius, but used the original and added something simple to it. I am sure Kent Cooper's is better. (defun C:FMP_R (/ plss n rad) (setq rad (getdist "\nEnter fillet radius: ")) (if (and rad (> rad 0.0)) (progn (command "_.fillet" "_radius" rad) (if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ) ) ) ) (princ) ) 1 Quote
Nikon Posted yesterday at 04:02 PM Posted yesterday at 04:02 PM (edited) Lee Mac has a similar code. The FMP_R and fpoly codes perform conjugations with a given radius. Only in these codes it is impossible to set the value radius = 0. Is there a code for interfacing with a radius of 0? There's also the marko_ribar code, but I couldn't verify it. When loading, the message appears: Unknown command. Edited yesterday at 04:11 PM by Nikon Quote
SLW210 Posted 6 hours ago Posted 6 hours ago Did you bother to check the link I posted? The first one in my link from Kent Cooper will do fillet>R>0 if that is the value of FILLETRAD. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/6473166#M130031 The FilletMultiplePolylines will work with 0 radius. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/10151411#M130041 Quote
Nikon Posted 4 hours ago Posted 4 hours ago 1 hour ago, SLW210 said: Did you bother to check the link I posted? Unfortunately, I couldn't check, the link doesn't open for me... Quote
Nikon Posted 2 hours ago Posted 2 hours ago 4 hours ago, SLW210 said: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/6473166#M130031 Can anyone attach a lisp from this link? Quote
GLAVCVS Posted 2 hours ago Posted 2 hours ago (defun C:FMP (/ plss n) (if (setq plss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ); repeat ); if (princ) I guess this is it 1 Quote
Nikon Posted 1 hour ago Posted 1 hour ago (edited) 1 hour ago, GLAVCVS said: (defun C:FMP (/ plss n) (if (setq plss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ); repeat ); if (princ) This code should perform the pairing (without specifying the radius?). The code doesn't work: unknown command. The parenthesis after (princ) is lost. +) Edited 51 minutes ago by Nikon Quote
Nikon Posted 1 hour ago Posted 1 hour ago (edited) 6 hours ago, SLW210 said: The first one in my link from Kent Cooper will do fillet>R>0 if that is the value of FILLETRAD. The code can connect several polylines with a radius of 0. I understood that FILLETRAD must be set beforehand. Or do this: (defun C:FMP0 ; = Fillet Multiple Polylines (/ plss n) (setvar "FILLETRAD" 0) (if (setq plss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ); repeat ); if (princ) ); defun Or a different code for different radii, and you can also use 0. (defun C:FMP01 (/ rad plss n) (setq rad (getreal " Enter the fillet radius (you can use 0): ")) (setvar "FILLETRAD" rad) (if (setq plss (ssget '((0 . "LWPOLYLINE")))) (repeat (setq n (sslength plss)) (command "_.fillet" "_polyline" (ssname plss (setq n (1- n)))) ) ) (princ) ) Edited 10 minutes ago by Nikon Quote
