masterfal Posted yesterday at 02:38 AM Posted yesterday at 02:38 AM Hi All, i've been using viewport outline for years (props to lee mac, of course) and have noticed after switching to autocad 2026 the vpoa command (thats where it automatically generates outputs for all viewports) doesn't seem to generate the outlines into modelspace anymore. vpo works (thats where you select the viewport first). i tested on autocad 2022 and works fine there. any suggestions how this can be fixed to work with 2026? VPOutlineV1-3.lsp Quote
SLW210 Posted 17 hours ago Posted 17 hours ago I tried a couple of drawings with multiple tabs and it seems to be working on my AutoCAD 2026. Might be another LISP interfering. 1 Quote
mhupp Posted 4 hours ago Posted 4 hours ago This isn't feature rich as Lee's and uses command quite a bit. never got around to updating it. VP2M.lsp Quote
masterfal Posted 1 hour ago Author Posted 1 hour ago 15 hours ago, SLW210 said: I tried a couple of drawings with multiple tabs and it seems to be working on my AutoCAD 2026. Might be another LISP interfering. strange.. im running same routines on 2022 as i do on 2026. i shall do a bit more investigating. cheers for the info Quote
masterfal Posted 1 hour ago Author Posted 1 hour ago all sorted. my 2022 version was set up with regen when changing layouts but my 2026 wasn't set the same meaning i couldn't see the changes when i switched to modelspace without a manual regen Quote
