Hi
I´m a little bit rusti in AC. I resently worked in AC12 but have just bougt AC22.
I have loaded my old homemade menufiles from AC12 to AC22, but i can´t get my pulldown-bars etc. up on the screen.
How do i do that...?
John
Where your menu's, MNU or CUI/CUIX files ? Either way you use menuload or menuunload to remove sometimes have to do that before reloading.
If your custom menu is inside a "ACAD.mnu" then you may have a problem.
Can you please confirm.
I´m using cuix-files and i hav tried to unload and after that to reload the menufile. The file do load as it suppose to, but i can´t get the toolbars, pulldown etc. up on the screen....?
You haven't mentioned what you have tried so far.
If you haven't already, MENUBAR to 1, then go to Tools>Hover over Toolbars, should be a dropdown to select the toolbar group you need.
If you already have a toolbar docked, just Right-Click an empty area.
Thanks for your responce.
I found a solution and it´salle working....😁
Would you mind sharing the solution?
Yep same for if you do or dont like the Ribbon.
Ribbonclose and Ribbon.
Edited by BIGAL
A little tip - when you find setting like these that sets CAD to how you like it, put them into a LISP (setvar 'menubar 1) for example - mine is saved something like CADSettings.LSP... so that when it is upgrade time there is half a chance of a quick fix to make thing 'correct' - or spend a day trying to remember what you did 2, 5 or 10 years ago. Add comments so you know what each does,
Edited by Steven P
  • Agree 1
