john madsen Posted 23 hours ago Posted 23 hours ago Hi I´m a little bit rusti in AC. I resently worked in AC12 but have just bougt AC22. I have loaded my old homemade menufiles from AC12 to AC22, but i can´t get my pulldown-bars etc. up on the screen. How do i do that...? John Quote
BIGAL Posted 16 hours ago Posted 16 hours ago Where your menu's, MNU or CUI/CUIX files ? Either way you use menuload or menuunload to remove sometimes have to do that before reloading. If your custom menu is inside a "ACAD.mnu" then you may have a problem. Can you please confirm. Quote
john madsen Posted 4 hours ago Author Posted 4 hours ago I´m using cuix-files and i hav tried to unload and after that to reload the menufile. The file do load as it suppose to, but i can´t get the toolbars, pulldown etc. up on the screen....? Quote
SLW210 Posted 2 hours ago Posted 2 hours ago You haven't mentioned what you have tried so far. If you haven't already, MENUBAR to 1, then go to Tools>Hover over Toolbars, should be a dropdown to select the toolbar group you need. If you already have a toolbar docked, just Right-Click an empty area. Quote
john madsen Posted 1 hour ago Author Posted 1 hour ago Thanks for your responce. I found a solution and it´salle working.... Quote
