hello:
Does anyone have something that does this or something similar?
Break the lines and draw those symbols
Any comments are welcome, thank you.
A small modification of the DZ code for convenience.
The Break lines can be lengthen by the specified distance (Fixed)
or proportionally (by 1/3) or None.
[Fixed/Proportional/None]
;;; Lisp to draw Single or Double "Z" Break Lines
;;;                 © A.Henderson 2002
;;;  Modified By Charles Alan Butler  10/06/2004
;;;  To allow any angle and to trim lines that
;;;  do not run through both break symbols
;;;  Modified 12/02/26
;;;  The Break lines can be lengthen by the specified distance (Fixed)
;;;  or proportionally (by 1/3) or None
(defun c:dz-mod (/ oldlay oldotho oldosmode ztype dist ang
             extOpt extLen dist0 segLen
             e1 e2 p1 p2 p3 p4 p5 p6 p7 p8 p9 p10)
  ;; return vertex list by MP
  (defun cdrs (key lst / pair rtn)
    (while (setq pair (assoc key lst))
      (setq rtn (cons (cdr pair) rtn)
            lst (cdr (member pair lst))
    (reverse rtn)
  ) ; defun
  ;;  set osnaps ON/OFF
  (defun setosnaps (value) ; value = "ON" or default to "OFF"
    (if value
      (setq value (strcase value))
    (cond
      ((or (and (= value "ON") (>= (getvar "osmode") 16383))
           (and (/= value "ON") (<= (getvar "osmode") 16383))
       (setvar "osmode" (boole 6 (getvar "osmode") 16384))
  ); defun
  ;;   Start of routine  ==================================
  ;;  Save settings
  (setq oldlay    (getvar "clayer")
        oldortho  (getvar "orthomode")
        oldosmode (getvar "osmode")
  ) ;_ end of setq
  ;;  I use current layer - CAB
  ;;(command "_.layer" "_make" "Z-Line" "_Colour" "41" "" "")
  (initget "S D")
  ;(setq ztype (getkword "\n Single or Double -^v-^v- ? (S or D) <S>"))
  (setq ztype (getkword "\n Single or Double -^v-^v- ? [S/D] <S>"))
  (setosnaps "ON") ; force on
  (if (and (setq p1 (getpoint "Starting point of break line : "))
           (setq p6 (getpoint p1 "End point of break line : "))
    (progn;===========================================
      ;;; --- EXT --- calculate the base length/angle based on the selected points
      (setq dist0 (distance p1 p6))
      ;;; --- EXT --- elongation mode (Fixed = 50 by default)
      (initget "F P N")
      (setq extOpt (getkword "\nExtend beyond picked points? [Fixed/Proportional/None] <Fixed>: "))
      (cond
        ((or (not extOpt) (= extOpt "F"))
          (setq extLen (getdist "\nExtension length <50>: "))
          (if (null extLen) (setq extLen 50.0))
        ((= extOpt "P")
          ;; 1/3 of the straight section (straight section = 0.4167*dist for S, and 0.4167*(dist/2) for D)
          (setq segLen (* 0.4167 (if (= ztype "D") (/ dist0 2.0) dist0)))
          (setq extLen (/ segLen 3.0))
        (T (setq extLen 0.0))
      (setvar "plinewid" 0)
      (command "._undo" "_begin")
      (cond
        ((/= ztype "D") ; default to single
         (setq dist (distance p1 p6)
               ang  (angle p1 p6)
               p2   (polar p1 ang (* 0.4167 dist))
               p5   (polar p1 ang (* 0.5833 dist))
               p3   (polar p2 (+ 1.25664 ang) (* 0.1667 dist))
               p4   (polar p5 (+ 4.39824 ang) (* 0.1667 dist))
         ) ;_ end of setq
         ;;; --- EXT ---  we only lengthen the ends (the symbol remains at the base points)
         (setq p1 (polar p1 (+ ang pi) extLen)
               p6 (polar p6 ang extLen)
         (setosnaps "OFF") ; force off
         (command "_.pline" p1 p2 p3 p4 p5 p6 "") ; Draw the Z-Line
        ) ;_ end cond "S"
        ((= ztype "D")
         (setq p10  p6
               dist (/ (distance p1 p6) 2.0)
               ang  (angle p1 p6)
               p6   (polar p5 ang (* 0.8334 dist))
               p9   (polar p6 ang (* 0.1661 dist))
               p7   (polar p6 (+ 1.25664 ang) (* 0.1667 dist))
               p8   (polar p9 (+ 4.39824 ang) (* 0.1667 dist))
         ) ;_ end of setq
         ;;; --- EXT ---  we extend the start and the very end (p10), we do not touch the inside
               p10 (polar p10 ang extLen)
         (command "_.pline" p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 "") ; Draw the Z-Line
        ) ;_ end cond
      ) ; end cond stmt
      ;;  Position the second break line
      (setq e1 (entlast))
      (command "_.pedit" e1 "_L" "_ON" "")
      (command "_.copy" e1 "" (getvar "lastpoint") pause)
      (setq e2 (entlast))
      (setq plast (getvar "lastpoint"))
  ;;  trim function
      (initget "Y N")
      (setq ans (getkword "
Do you wish to trim the lines now ? [Y/N] <Y>"))
      (if (or (= ans "Y") (not ans))
          (setq lst  '()
                dist (/ dist 140.0) ; trim distance
          ;;  create trim lines
          (command "._offset" dist e1 plast "")
          (setq evl1 (cdrs 10 (entget (entlast)))) ; ent vertex list
          (entdel (entlast))
          (command "._offset" dist e2 p1 "")
          (setq evl2 (cdrs 10 (entget (entlast))))
          (entdel (entlast))
          (setq lst (append evl1 (reverse evl2)))
          (command "_.trim" e1 e2 "" "_F")
          (apply 'command lst)
          (command "" "")
          (command "" "")
        ) ; progn
      ) ;_ endif
      (command "._undo" "_end")
    ) ; progn
  ) ; endif
  ;;  Exit sequence
  ;;  Restore settings
  ;;(command "_.layer" "set" oldlay "")
  (setvar "orthomode" oldortho)
  (setvar "osmode" oldosmode)
) ;_ end of defun
(prompt
  "\nDouble Break Symbol Creator loaded.  Type DZ to run it."
(setfunhelp "c:dz" "acadtools.chm" "dz")
Edited by Nikon
  • Thanks 1
I think a custom DCL front end would be good. Will have a think about it. The extend option is easy just set the default length to 0.0 so any other value means yes.
Nikon the dynamic block is a nice idea.
Edited by BIGAL
Thought I had posted this a dcl front end.
(defun inputinfo ( / AH:setvals dcl des)
(defun AH:setvals ( / )
(if(= (get_tile "Rb1") "1")
  (setq ztype "S")
  (setq ztype "D")
(cond
((= (get_tile "Rb3") "1")(setq extop "F"))
((= (get_tile "Rb4") "1")(setq extop "P"))
((= (get_tile "Rb5") "1")(setq extop "N"))
(setq extlen (atof  (get_tile "val1")))
(setq dcl (vl-filename-mktemp "" "" ".dcl"))
(setq des (open dcl "w") )
(foreach x
"brklines : dialog 	{"
"	label =\"Please choose\" ;"
"	: row	{"
"	: boxed_radio_column 	{"
" width = 23 ;"
"	label =\"Single or Double\" ;"
"spacer_1 ;"
"	: radio_button	{"
"key = \"Rb1\";"
"label = \"Single\" ;"
"spacer_1 ;"
"	: radio_button	{"
"key = \"Rb2\";"
"label = \"Double\" ;"
"spacer_1 ;"
"	: row	{"
" width = 23 ;"
"	label =\"Extend beyond picked points\" ;"
"spacer_1 ;"
"	: radio_button	{"
"key = \"Rb3\";"
"label = \"Fixed\" ;"
"spacer_1 ;"
"	: radio_button	{"
"key = \"Rb4\";"
"label = \"Proportional\" ;"
"spacer_1 ;"
"	: radio_button	{"
"key = \"Rb5\";"
"label = \"None\" ;"
"spacer_1 ;"
"	: row	{"
": edit_box {"
"	label = \"Extension length\" ;"
"spacer_1 ;"
" width = 25 ;"
"key = \"val1\" ;"
"     edit_width = 10 ;"
"     edit_limit = 9 ;"
"   is_enabled = true ;"
"   allow_accept=true ;"
"spacer_1 ;"
"	ok_cancel ;"
(write-line x des )
(close des)
(setq dcl_id (load_dialog dcl))
(if (not (new_dialog "brklines" dcl_id) )
(exit)
(set_tile "Rb1" "1")
(set_tile "Rb3" "1")
(set_tile "val1" "50.0")
(action_tile "accept" "(AH:setvals)(done_dialog)")
(action_tile "cancel" "(done_dialog)(exit)")
(start_dialog)
(unload_dialog dcl_id)
(vl-file-delete dcl)
(inputinfo)
I use a block with mask/wipeout, scaled up, then xclipped to trim the extent of lines. Allows easy moving and 'breaking' of hatch patterns without actually breaking anything.
sym-breakline-mask.dwg
