Hello, I'm trying to create a macro to dimension angles using a vertex starting at 0,0 to 0,1, and then a point. I thought it would be rather simple compared to other things that I have tried.
I thought that this would do what I want, but for some reason the first line in the angle is all over the place. Any ideas as to why?
^C^C^C_dimangular;;0,0;0,1;\
LOL @zaphod - your username wouldn't be a reference to "Zaphod Beeblebrox" would it? :)
Sorry i didn't answer you're OG question - just a Douglas Adams nerd haha.
Seriously, I think the problem is the second point must be in a clockwise direction from the first line, meaning if you select an area in the first quadrant you are in a counter-clockwise rotation, and it will give you the obtuse side of the circle instead of the inside angle. For doing an angle from 0-90deg, you would need to start at 0,0;1,0 instead.
Edited by pkenewell
Indeed, it is sir. Thank you for looking into this issue of mine.
Although I'm not certain of what causes the error that I'm seeing, I have the same "Macro" written out on one of my gaming devices, it works, until AutoCAD becomes a dyslexic child. That caused me to look for an "internal" method to AutoCAD.
Starting at around 2°, these were my results this morning. Multiple completely different random starting lines.
I'm not sure what you mean by changing the start point, I want it to start on the 0° axis from 0,0.
I do not use "Dynamic Input" or "Dynamic UCS".
solution from the Autodesk forums
"*^C^C^C_dimangular;;non;0,0;non;0,1;\NON"
Ah Yes - those pesky object snaps getting in the way!
What I meant was changing the starting axis from Y (0,0;0,1) to the X axis (0,0;1,0) for angles going CCW within 0 to 90 deg. Sounds like I misunderstood the problem though?
