CHAKRADHAR Posted 11 hours ago Posted 11 hours ago (edited) In ZWCAD 2026, our drawing uses isocp.shx font inside block attributes. When exporting to PDF, the SHX text is converted to geometry and becomes non-editable in Foxit. Is there any way to export SHX text as real editable text without changing the drawing font standard? text issue.dwg without sign 1.pdf Edited 11 hours ago by CHAKRADHAR I HAVE SUBMITED PDF FILE CAN ANY EDIT SHX FONT IN PDF Quote
CyberAngel Posted 4 hours ago Posted 4 hours ago You may not have a choice here, but can you convert your text to TTF from SHX? PDF should accept that as text. Quote
SLW210 Posted 1 hour ago Posted 1 hour ago I can do that most of the time with the OCR (Optical character recognition) in Adobe Acrobat Pro. I thought Foxit has an OCR. Quote
