dickeychan Posted 4 hours ago Posted 4 hours ago is there any opinion to "hide" the center node...? sometime I use DimArc at Pspace, the center node shown outside the title block... (or DimArc at Mspace, the center node shown at the outer space...) it affects Zoom~Extents and choosing Extents as plot area... (gotta use Window to point-pick plot area... ย it's pretty trouble as I use Page Setup to Publish outputs very often...) Quote
SLW210 Posted 2 hours ago Posted 2 hours ago I moved your thread to theย AutoCAD 2D Drafting, Object Properties & Interface Forum. ย It is indeed a pain. ย Your only options AFAIK, use LIMITS instead of EXTENTS or EXPLODE the Dimension. Quote
