is there any opinion to "hide" the center node...?
sometime I use DimArc at Pspace, the center node shown outside the title block...
(or DimArc at Mspace, the center node shown at the outer space...)
it affects Zoom~Extents and choosing Extents as plot area...
(gotta use Window to point-pick plot area...
 it's pretty trouble as I use Page Setup to Publish outputs very often...)
Welcome to Cadtutor.
You can draw a rectang that represents your viewport for a given scale matching a known title block. It is a lisp program. Just pick a point in model space, the rectang can be moved and/or  rotated, part 2 is make a matching layout. So can see the dim problem and make some choices.
Just ask if sounds helpful.
