bustr Posted 1 hour ago Posted 1 hour ago (edited) The text replacer lisp refuses to work when there is a # in the text string tobe replaced or the string to replace it. Does anyone know how to fix? revised per #555188 revised per #666299 TXTREPLACE.LSP Edited 1 hour ago by bustr Quote
pkenewell Posted 51 minutes ago Posted 51 minutes ago Why not just use the built-in FIND command in AutoCAD? You just have to turn off the "Use Wildcards" option. 1 Quote
bustr Posted 26 minutes ago Author Posted 26 minutes ago 24 minutes ago, pkenewell said: Why not just use the built-in FIND command in AutoCAD? You just have to turn off the "Use Wildcards" option. That works well if there is only one value that needs to be replaced. Thanks. Quote
