Question in code..
(defun c:CopyRegionEdge (/ ss) ;; AI.. https://www.google.com/search?q=copy+region+edge+segment%2C+autolisp&client=firefox-b-1-e&hs=LJSp&sca_esv=28d160b4388e87a1&biw=1143&bih=530&ei=t2enadf8OfXIp84PyJ69kA8&ved=0ahUKEwiXtPqy6oSTAxV15MkDHUhPD_I4ChDh1QMIEQ&uact=5&oq=copy+region+edge+segment%2C+autolisp&gs_lp=Egxnd3Mtd2l6LXNlcnAiImNvcHkgcmVnaW9uIGVkZ2Ugc2VnbWVudCwgYXV0b2xpc3AyCBAAGIAEGKIEMgUQABjvBTIFEAAY7wUyBRAAGO8FMgUQABjvBUjeM1C3D1iRLnABeACQAQCYAYgIoAHMC6oBBzAuNC43LTG4AQPIAQD4AQGYAgagApcNwgIIEAAYsAMY7wXCAgoQIRigARjDBBgKmAMAiAYBkAYFkgcHMS40LjYtMaAH0BCyBwcwLjQuNi0xuAffDMIHBzItMS4zLjLIB2uACAA&sclient=gws-wiz-serp
   ;; micro altered..
  (princ "\nSelect Region to Copy Edge From: ")
(setvar 'cmdecho 0)
  (if (setq ss (ssget ":S" '((0 . "REGION"))))
	    (command "_.copybase" "0,0,0" ss "") ;; copy region to clipbrd
	    (command "chprop" ss "" "c" 252 "") ;; change color
	    (command "_.explode" ss)     ;; make segs accessable <not a selection set>
	   (princ "\nSelect Region Seg to Copy ")
	    (command "_.copy" (ssget ":S") "" "\\" "\\") ;; select seg +copy +move
	    (command "_.erase" ss "")
	    (princ "\nSelect Items to Remove..") ;; <- my only known method
	    (command "_.erase" "w" "\\" "\\" "") ;; <- manual erase :(
	    ;; ...  SEEING AS MY AUTOLISP EXPERIENCE SUCKS ..
	    ;;  how can the eXploded region / lines etc, be ERASED/selected ?
	    ;; how to: make a selection set?
	    (command "chprop" "_L" "" "c" "bylayer" "") ;; ch copied to bylayer
  (command "_.pasteclip" "0,0,0") ;; re.place original region
  (setvar 'cmdecho 1)
Edited by ScottMC
not sure what your trying to do. you can set entlast before the explode then add all the entities into the selection set.
(setq LastEnt (entlast))
(setq SS1 (ssadd)) ;create a blank selection set or add to an existing one.
(while (setq LastEnt (entnext LastEnt))
  (ssadd LastEnt SS1)
