ScottMC Posted 11 hours ago Posted 11 hours ago (edited) Question in code.. (defun c:CopyRegionEdge (/ ss) ;; AI.. https://www.google.com/search?q=copy+region+edge+segment%2C+autolisp&client=firefox-b-1-e&hs=LJSp&sca_esv=28d160b4388e87a1&biw=1143&bih=530&ei=t2enadf8OfXIp84PyJ69kA8&ved=0ahUKEwiXtPqy6oSTAxV15MkDHUhPD_I4ChDh1QMIEQ&uact=5&oq=copy+region+edge+segment%2C+autolisp&gs_lp=Egxnd3Mtd2l6LXNlcnAiImNvcHkgcmVnaW9uIGVkZ2Ugc2VnbWVudCwgYXV0b2xpc3AyCBAAGIAEGKIEMgUQABjvBTIFEAAY7wUyBRAAGO8FMgUQABjvBUjeM1C3D1iRLnABeACQAQCYAYgIoAHMC6oBBzAuNC43LTG4AQPIAQD4AQGYAgagApcNwgIIEAAYsAMY7wXCAgoQIRigARjDBBgKmAMAiAYBkAYFkgcHMS40LjYtMaAH0BCyBwcwLjQuNi0xuAffDMIHBzItMS4zLjLIB2uACAA&sclient=gws-wiz-serp ;; micro altered.. (princ "\nSelect Region to Copy Edge From: ") (setvar 'cmdecho 0) (if (setq ss (ssget ":S" '((0 . "REGION")))) (progn (command "_.copybase" "0,0,0" ss "") ;; copy region to clipbrd (command "chprop" ss "" "c" 252 "") ;; change color ;;; ??????????? (command "_.explode" ss) ;; make segs accessable <not a selection set> (princ "\nSelect Region Seg to Copy ") (command "_.copy" (ssget ":S") "" "\\" "\\") ;; select seg +copy +move (command "_.erase" ss "") (princ "\nSelect Items to Remove..") ;; <- my only known method (command "_.erase" "w" "\\" "\\" "") ;; <- manual erase :( ;; ... SEEING AS MY AUTOLISP EXPERIENCE SUCKS .. ;; how can the eXploded region / lines etc, be ERASED/selected ? ;; how to: make a selection set? (command "chprop" "_L" "" "c" "bylayer" "") ;; ch copied to bylayer ) ) (command "_.pasteclip" "0,0,0") ;; re.place original region (setvar 'cmdecho 1) (princ) ) Edited 11 hours ago by ScottMC .. Quote
mhupp Posted 9 hours ago Posted 9 hours ago not sure what your trying to do. you can set entlast before the explode then add all the entities into the selection set. (setq LastEnt (entlast)) (command "_.explode" ss) (setq SS1 (ssadd)) ;create a blank selection set or add to an existing one. (while (setq LastEnt (entnext LastEnt)) (ssadd LastEnt SS1) ) Quote
marko_ribar Posted 1 hour ago Posted 1 hour ago (edited) If I understood you correctly, you are searching to something like this... (defun c:copy_reg_edg ( / car-sort regpt reg x pt el ell edg ) (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com)) (defun car-sort ( lst fun / r ) (setq r (car lst)) (foreach itm (cdr lst) (if (apply fun (list itm r)) (setq r itm) ) ) r ) (if (and (setq regpt (entsel "\nPick edge of region to copy...")) (setq reg (car regpt)) (= (cdr (assoc 0 (setq x (entget reg)))) "REGION") (/= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 x)))))))) (progn (setq pt (trans (osnap (cadr regpt) "_nea") 1 0)) (setq el (entlast)) (vla-explode (vlax-ename->vla-object reg)) (while (setq el (entnext el)) (setq ell (cons el ell)) ) (setq edg (car-sort ell (function (lambda ( a b ) (< (distance pt (vlax-curve-getclosestpointto a pt)) (distance pt (vlax-curve-getclosestpointto b pt))))))) (foreach el ell (if (not (eq el edg)) (entdel el) ) ) (vl-cmdf "_.copy" edg "" "_non" (trans pt 0 1) "\\") (entdel edg) ) (prompt "\nMissed, or picked wrong entity type - you must pick REGION entity on unlocked Layer... Better luck next time...") ) (princ) ) Edited 1 hour ago by marko_ribar Quote
ScottMC Posted 1 hour ago Author Posted 1 hour ago PURRRFECT! Thanks so much 'mhupp This gets me all.the.more excited to learn more! Quote
ScottMC Posted 1 hour ago Author Posted 1 hour ago (edited) Marco, when'd u write that? let me try it... seems to refuse arc segs but do like your select style Edited 1 hour ago by ScottMC Quote
marko_ribar Posted 16 minutes ago Posted 16 minutes ago I tested it under AutoCAD 2022 and BricsCAD V26 and it worked well and with arced segments... Do you receive some error messages? Quote
