Hey, I've got a project that requires me to reproduce/trace a 3D spline, with ARC segments.  The goal being to reproduce the SPLINE as accurately as possible, with as few ARCs as possible
Just hoping to get some thoughts on methods to approach this challenge.  Right now my method is to divide the SPLINE into sections based on the local normal-ness of part of the SPLINE.  Just visually trying to fit each ARC to a portion of the SPLINE
I have to perform this task 8 times for this project so hoping to come up with a neat and robust method
DWG attached - in this example I am trying to work to a limit of 5 ARCs
TEMP.dwg
Obviously, you can't use the original spline or you'd be doing that. It might help us to know why, though.
I assume the goal is a 2D spline. Have you thought about starting with an actual spline? That way you can adjust the control points and their tangents, instead of using polyline arcs, which seems more complicated.
If the goal is a 2D polyline, you can still draw it with a spline and then convert it to a polyline with SPLINEDIT.
The more we know about your project, the better we can help. Right now I'm just guessing.
Hey thanks for the reply
The reason to convert to a small quantity of ARCs is because the SPLINE will become fabricated out of steel pipe.  Fab method requires the shape to be fabricated from curved pipe segments.  Unfortunately for this project, corkscrew/spiral pipe segments are not an option, so we are stuck with ARCs
As I understand your question your goal is to approximate a 3D spline as a series of arcs (2d of course) that are positioned in series.
To get a feel for the 3D nature and curvature of the spline I suggest first running my splinecurvature LISP program on the spline.  Respond Y to the prompt:
                     Do you want radius-of-curvature instead of curvature? [y/n] <n>: y
and you will get a result like the following:
The red lines are created at 100 points along the spline.  They show the instantaneous radius of curvature of the spline at the points.  The ends of the red lines are at the locations of the center of an arc that would duplicate the spline's curvature for a specific point on the spline.
With this information you need to choose, starting at one end of the spline, 3 points along the spline that are in a generally "flat" area.  Define a UCS for the 3 points then add an arc via the three point method.   Repeat the process for the next "flat" section.
Here are the results for two arcs.
(defun C:SplineCurvatue (/ path inc n osm par der1 der2 curva p perp normv p2 sf
	       curveType ans)
; = Degree Of Curvature - Lines
; Creates curvature lines or radius-of-curvature lines
; normal to a spline.
; LRM 8/18/2022 edited to place curvature vectors outside
  (setq
    path (car (entsel))
    inc	 (/ (vlax-curve-getEndParam path) 100)
    n	 0
    osm	 (getvar 'osmode)
  (setvar 'osmode 0)
  (setvar "cmdecho" 0)
  (initget "y n")
  (setq ans (getkword  "Do you want radius-of-curvature instead of curvature? [y/n] <n>: "))
	(if (= ans "y")
	   (setq curveType 1)
	   (setq curveType 2
		 sf	   (getdist "Enter scale factor.")
  (repeat 100
    (setq par (* inc n))
    (setq der1 (vlax-curve-getfirstDeriv path par)
	  der2 (vlax-curve-getSecondDeriv path par)
    ; calculate curvature at point par
    (setq d (distance '(0 0 0) (cross der1 der2)))
    (if	(> (abs d) 1.0e-15)
	(setq curva (/ (expt (distance '(0 0 0) der1) 3) d))
	(if (= curveType 2)
	    (setq curva (* -1. (* sf (/ 1. curva))))
	(princ "\n") (princ n)
	(princ "   curvature = ") (princ curva)
	(setq p	    (vlax-curve-getPointAtParam path par)
	      perp  (unitv (cross der1 (cross der2 der1)))
	      normv (mapcar '* perp (list curva curva curva))
	      p2    (mapcar '+ p normv)
	(command "_.line" p p2 "")
      )					; end progn
    (setq n (1+ n))
  (setvar 'osmode osm)
  (setvar "cmdecho" 1)
  ;;; Compute the cross product of 2 vectors a and b
(defun cross (a b / crs)
  (setq	crs (list
	      (- (* (nth 1 a) (nth 2 b))
		 (* (nth 1 b) (nth 2 a))
	      (- (* (nth 0 b) (nth 2 a))
		 (* (nth 0 a) (nth 2 b))
	      (- (* (nth 0 a) (nth 1 b))
		 (* (nth 0 b) (nth 1 a))
	    )				;end list
  )					;end setq c
)					;end cross
  (defun unitV ( v / d)
  (setq d (distance '(0 0 0) v)
	d (mapcar '/ v (list d d d))))
SplineCurvature.lsp
Wow nice that looks like a very interesting tool, thanks lrm
Your understanding of my task is correct.  And your suggested workflow is pretty much what I have been doing (except without your LISP of course), and I was using 3DFACE to allocate my 'flat' points.  One of the biggest and time consuming challenges has been to determine which points I will use to fit the ARCs to, while also maximising fit accuracy and also smoothness of the transition to the next ARC.  I think your routine will  come on quite handy to help me decide where to  finish 1 ARC and begin the next
Thanks again for sharing!
@lamensterms
I'm glad you found spline curvature VLISP program helpful.
Here's another program that you may find useful.  It creates an arc through three point that may lie in 3D. Note,  the ucs command would not use the 3 world points to correctly define the ucs I wanted so I had to use the more complex  Z axis method in VLISP.
; create an arc through 3 points in 3D space
; lrm 3/9/2026
(defun c:arcIn3D( /  p1 p2 p3 zpoint p1u p2u p3u)
  (command "_ucs" "w")
  (setq p1 (getpoint "\nPick start of arc: ")
	p2 (getpoint p1 "\nPick next point for arc: ")
	p3 (getpoint p2 "\nPick end point of arc: "))
(setq zpoint (mapcar '+ p1 (cross (mapcar '- p2 p1) (mapcar '- p3 p1))))
  (command "_ucs" "za" "_non" p1 "_non" zpoint)
  (setq p1u (trans p1 0 1)
	p2u (trans p2 0 1)
	p3u (trans p3 0 1))
  (command "_arc" "_non" p1u "_non" p2u "_non" p3u)
; cross product of vectprs a and b
  (setq	crs (list
	    )				;end list
  )					;end setq c
)					;end cross
arc_in_3d_space.lsp
Oh that's cool, thanks for that lrm that will save quite a few steps in my process!
Thanks again
