This lisp puts dimensions on a pline, how can I have it put the dimensions above the pline? Also it doesn't put a dimension on the last line.
(defun c:PLD (/ ent obj i p1 p2)
  (vl-load-com)
  (if (setq ent (car (entsel "\nSelect Polyline to Dimension: ")))
      (setq obj (vlax-ename->vla-object ent))
      (if (= (vla-get-ObjectName obj) "AcDbPolyline")
          (setvar "cmdecho" 0)
          (command "._undo" "_begin")
          (setq i 0)
          ;; Loop through vertices
          (repeat (fix (- (vlax-curve-getEndParam obj) 1))
            (setq p1 (vlax-curve-getPointAtParam obj i)
                  p2 (vlax-curve-getPointAtParam obj (1+ i)))
            ;; Create aligned dimension
            (command "_.dimaligned" "_none" p1 "_none" p2 "_none" (polar p1 (+ (angle p1 p2) (/ pi 2)) 1.0))
            (setq i (1+ i))
          (command "._undo" "_end")
          (setvar "cmdecho" 1)
        (princ "\nSelected object is not a LightWeight Polyline.")
(princ "\nType 'DimPlineSegments' to run.")
Edited by SLW210
Added Code Tags!!
In the future please place your code in Code Tags. (<> in the editor toolbar)
