Just found out that 'my program' refuses transparent use of a variable saved.
This happens only when trying to use a saved variable when it's 'my program'.
The variable is unrecognized: Example..
Command: c2
 2.Point Circle (M) <'CT for.tan !pp>
 Specify 1st Point of 2P.Circle: !pp
Invalid 2D point.                         /\ <- keyed variable call
Here's the original reply..
Command: c
CIRCLE Specify center point for circle or [3P/2P/Ttr (tan tan radius)]: 2p
Specify first end point of circle's diameter: !pp
"39.5838,25.6142,0"         <--------------- call /\ works
the /\ contents are actually without parenthesis but appear as shown.
           Command: (princ (getenv "pp"))
             39.5838,25.6142,0"39.5838,25.6142,0"
How can the code be changed to allow [ !pp ]?
Also tested this by making a base command (no extras) and the results are the same.
(defun c:c2 ( / *error* p oldsnap 1st) ;just 2 point.. //wasCIRCLE TANGENT RE: 19SEPT17
  (princ "\n 2.Point Circle (M) <'CT for.tan !pp> ")
  (setq pp "")
     (setq oldsnap (getvar 'osmode))
       (setvar 'osmode (boole 7 (getvar 'osmode) 512)) ;; added 'nea for 1st point
   (defun *error* ( msg )
      (setvar 'cmdecho 0) ;; 5.28.24
     (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
        (setvar 'osmode oldsnap)
     (if msg (prompt (strcat "\n" msg)))
      (if (eq pp "") (setq pp (getenv "pp"))) ;; restores stored <!pp> from "pp" if crash
     (setvar 'cmdecho 1)
  (initget 103)
(princ "\n Specify 1st Point of 2P.Circle: ") ;; (rtos (getvar 'circlerad))">" ;; <- not needed
    (setvar 'cmdecho 0)
   (while T ;;                                  'M' loop..
   (setq 1st (getpoint)) ;; get 1st edge of '2p.cir
       (command ".circle" "2p" 1st)
       (setvar 'cmdecho 1)
          (while (= 1 (logand 1 (getvar 'cmdactive)))
          (setvar 'osmode (boole 7 (getvar 'osmode) 128))         ;(setvar 'osmode 128) ;; added 'perp
            (command "\\")
           (setq p2 (getvar 'lastpoint))
       (setq p (trans (cdr (assoc 10 (entget (entlast)))) (cdr (assoc 210 (entget (entlast)))) 1)) ;; 210 for 'z' direction
     (vl-cmdf "_copybase" '(0 0 0) "_L" "" "_erase"  "_L" "") ;; same as in: cut-... [ `` ]
    (setvar 'cmdecho 0)
        ; (princ
          ; (setq pp                               ;;  make/prints coords & paste usable
            ; (strcat
               ; (rtos (car p2) 2 4) ","        ;; 'p' -- vertex from pgm /\ getpoint,...
               ; (rtos (cadr p2) 2 4) ","
               ; (rtos (caddr p2) 2 4)
(princ "\n")
        (princ
            (strcat
               (rtos (car p) 2 4) ","        ;; 'p' -- vertex from pgm /\ getpoint,...
               (rtos (cadr p) 2 4) ","
               (rtos (caddr p) 2 4)
          (princ (strcat " | Ø: " (rtos (* (getvar 'circlerad) 2) 2 4)" | R: " (rtos (getvar 'circlerad) 2 4)))
       (entmakex (list (cons 0 "POINT") (cons 10 p))) ;; clean point
       (entmakex (list (cons 0 "POINT") (cons 10 p2))) ;; clean point
         (command "_pasteclip" '(0 0 0)) ;; restore circle [now 'last.obj]
        (setenv "pp" pp)
       ) ;; end of while
    (setvar 'cmdecho 1)
   (*error* nil)
Same function but not from a home.made cmd.
So these were the results that I got from the command line
Command: C
CIRCLE
Specify center point for circle or [3P/2P/Ttr (tan tan radius)]: 2P
"50,60,0"            <--------------- CALLING THE VARIABLE WORKS LIKE YOURS
Specify second end point of circle's diameter:
Command: C2
Can't reenter LISP.
Invalid point.           <--------------- CALLING THE VARIABLE DOESN'T WORKS LIKE YOURS
*Cancel*
Above the line that says invalid point you'll see it mentioned how you can't re-enter lisp. This means that if you wish to feed an autolisp variable into a custom autolisp coded command you can't feed it in like a regular command. I would hazard a guess the other issue is (if i'm reading it correctly) is that the variable is actually a string but the autolisp interpreter is expecting a list. I'm working on a few solutions in between work breaks (I am also in the Asia Pacific as well so its nearly bed time). But to proceed further if I may ask why are you writing the variable to the windows registry with the SETENV function?
@ScottMC
I don't see the purpose of why you are cutting the circle, printing the coordinates to the command line, then pasting the circle in the same loop?
- You don't need to initialize the pp variable as ""
- There is not apparent reason to cut and paste the circle.
- You do not need to put a Global variable into the registry to recall it again in the same session, even if the program stops.
Try out the following code:
(defun c:C2 (/ cr el *error* fp oe os p p2)
   (defun *error* (msg)
      (if oe (setvar "cmdecho" oe))
      (if os (setvar "osmode"  os))
      (princ (strcat "\n" msg))
   (vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
   (setq oe (getvar "cmdecho")
         os (getvar "osmode")
   (setvar "cmdecho" 0)
   (while (and
            (setvar 'osmode (boole 7 os 512))
            (setq fp (getpoint "\nSpecify 1st Point of 2P.Circle: "))
      (command "._Circle" "_2P" "_non" fp)
      (setvar "osmode" OS)
      (princ "\nSecond Point: ")
      (while (= (logand (getvar "cmdactive") 1) 1)
		   (command pause)
      (setq el (entget (entlast))
            p  (trans (cdr (assoc 10 el)) (cdr (assoc 210 el)) 1)
            p2 (getvar "lastpoint")
            cr (getvar "circlerad")
      (princ
         (strcat
            "\n Coordinates: "
            (setq C2:pp ;; Global Variable "C2:pp"
               (strcat
            "\n Diameter: "
            (rtos (* cr 2) 2 4)
            "| Radius: "
            (rtos cr 2 4)
            "\n"
Edited by pkenewell
Added Undo Start Mark and Better prompting to code.
  • Agree 1
100% setenv is writing strings to your windows registry. not good if you are doing that for all variables.  might want to check to see what else you have been writing there.
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R##.#\ACAD-####:###\Profiles\<<Unnamed Profile>>\Variables
tho setenv will persist even after reboot. overkill for most variables need in lisp. like @pkenewell said you should be good with just global variables. that holds while the drawing is open but make them unique. if you need to hold a variable in the drawing itself. use ldata that will persist in the drawing. so you can close and reopen it.
  • Like 2
pkenewell, used this make the circle the primary, last obj to select/edit
               the intention was to clear the global 'pp [true unneeded]
     q: is there a simpler way?
          and I use the coords so prefer it 'first' on the cmd-line for copy/paste
my reg use is 'very.small' - understand!
Edited by ScottMC
@ScottMC Sorry, I don't understand what you are trying to convey. Please try to explain better what you mean, or make some screenshots of what your intended outcome is.
re: I like it, while drawing, to 'pick what I've drawn with "L.ast" as I consider the circle the main entity created.
In trying other order changes, really haven't found much better. The cmd-line coords are not in question are
they? I prefer the coords that way for 'ease.of.use' on following commands. Suggestions, requests please.
Not sure if this is something to look at and lamda / mapcar
(car (mapcar '(lambda (a) (command "point" c) c) (setq c (getpoint "Get point"))))
will return the point of the point... and somehow wrap that into a circle command.. though just a quick look it didn't work for me. Thinking something like:
(command "circle" -lambda expression- -lambda expression-)
So the points are created first and then the circle created last. Someone might know the workings to make that work.
Have to use something like this to return a point as a part of another function
You could save (entlast) properties like centre and radius so (setq cprop (list pt rad))  a line (setq Lprop (list start end)) you can redefine commands like circle as a lisp Defun so it would ask for pt and rad if it does not exist or use pt again for something else. Is that what your thinking ?
As mentioned, my intention is to correct the 'post.create' entity selection to
be the circle as last.object. The other reason is for me to have visibility of the
2p.circle as I draw it. Attchd is the latest working..
Circle-2P.lsp
@ScottMC
Ok - I think I understand. You want to the Circle to be the last entity created, even though you added the points. That is relatively simple, just delete the circle and recreate it. See the update to my code below.
   (while (and
		   (command pause)
      (entdel (entlast)); Delete the Circle
      (princ
         (strcat
            "\n Coordinates: "
               (strcat
            "\n Diameter: "
            (rtos (* cr 2) 2 4)
            " | Radius: "
            (rtos cr 2 4)
            "\n"
      (entmakex (list (cons 0 "CIRCLE") (assoc 10 el) (assoc 8 el) (assoc 40 el))) ; Recreate the Circle
totally guessing but seems to crash on multi seq.
here's the mods u suggested added.
Guessing the:  (while (= (logand (getvar "cmdactive") 1) 1) ;; <--- might be crash source
didn't do a vlide source method yet.
So many of my copy/erase/paste to be replaced!
Thanks PK.
(defun c:c2 ( / *error* el p oldsnap 1st) ;just 2 point.. //wasCIRCLE TANGENT RE: 19SEPT17
     (setvar 'cmdecho 1)
  (initget 103)
    (setvar 'cmdecho 0)
   (setq 1st (getpoint "\n Specify 1st Point of 2P.Circle: ")) ;; get 1st edge of '2p.cir
       (setvar 'cmdecho 1)
          (setvar 'osmode (boole 7 (getvar 'osmode) 128))  ;; added 'perp
            (command "\\")
           (setq p2 (getvar 'lastpoint)) ;; posted \/ y,n?
         (setq el (entget (entlast))) ;; <-- removed replaced copy/erase
       (setq p (trans (cdr (assoc 10 el)) (cdr (assoc 210 el)) 1)) ;; 210 for 'z' direction
      (entdel (entlast)); Delete the Circle for last ent selection..
    (setvar 'cmdecho 0)
      (princ "\n")
        (princ
            (strcat
        (setenv "pp" pp) ;; sys saved, restored at restart
       ) ;; end of while
    (setvar 'cmdecho 1)
   (*error* nil) ;; restore saved vars
Edited by ScottMC
@ScottMC I don't recommend you put the OSMODE change in the CMDACTIVE loop. Here is how I would do it; tested this and it works perfectly.
   (while (and
      (command "._Circle" "_2P" "_non" fp "_per");; Add "PER" to overide OSNAP here.
		   (command pause)
      (princ
         (strcat
            "\n Coordinates: "
               (strcat
            "\n Diameter: "
            (rtos (* cr 2) 2 4)
            " | Radius: "
            (rtos cr 2 4)
            "\n"
If you don't want PERP to be the only snap available, then try your method, but before the CMDACTIVE loop:
       (setvar 'cmdecho 1)
          (command "\\")
Thanks PK for finding that. Something I've never found
or got direct connection to error but now will have that
as an understood rule. Will certainly look for that in
my troubleshooting.
just FYI for @ScottMC That while loop is running 1000's  times a sec and is intended to only pause waiting for user input to be completed. Can be simplified to this.
(while (> (getvar 'CMDACTIVE) 0)
  (Command  "\\")
Another option would be to use grread and grdraw to show a visualization of a circle but not actually add it to the drawing. Tho I found out it can only draws lines and you need to trick it to make segmented circles. will post something later tonight.
