[LISP] BPDF - Batch export Model Space title block frames to individual PDFs
Hi CADTutor,
I'm an architect in Taiwan and wrote a free AutoLISP
tool to solve a problem we face daily - batch exporting
all title block frames in Model Space to individual PDFs.
For those of us who work with all drawings arranged
in one Model Space (common workflow in Taiwan/Asia),
AutoCAD's built-in Batch Plot doesn't help much since
it works at the Layout level.
Features:
- Click on a title block frame to detect the Block name
  automatically
- Option to plot just that 1 frame, or all frames with
  the same name
- Sorts output top-to-bottom, left-to-right
- Dynamically loads plot styles and paper sizes from
  your machine
- Remembers last settings
- Compatible with AutoCAD 2014 and above
GitHub: https://github.com/beastt1992/autocad-batch-plot
Already tested by users on Reddit r/AutoCAD with good
feedback. A couple of bugs were found and fixed based
on community input (AC_WINDOW constant varies by version,
RefreshPlotDeviceInfo order).
Would love feedback from the AutoLISP community here -
especially if anyone tests it on different AutoCAD
versions or workflows!
So post the LISP so we can give feedback - it is easier to reference if the LISP is in the same thread as the comments and questions
Though I might be tempted to say change the system and get the draughters to use paperspace for what it is meant for.
(haven't had the paperspace / modespace discussion on here for a while now....)
Edited by Steven P
;;; BATCH-PDF
;;; Function: Batch export all title block frames to PDF
;;; Command: BPDF
;;; Compatible: AutoCAD 2014+
;;; v2.0 - Single-frame mode + cross-version compatibility
;;;        AC_WINDOW auto-detected (3 or 4)
;;;        RefreshPlotDeviceInfo order fixed for fresh sessions
(setq AC_0DEG 0)
(setq AC_FIT  0)
(defun BPDF-cfgpath ()
  (strcat (getenv "APPDATA") "\\bpdf_settings.cfg")
(defun BPDF-load-cfg ( / f line kv cfg)
  (setq cfg (list
    (cons "blockname" "")
    (cons "prefix" "frame")
    (cons "outpath" (strcat (getenv "USERPROFILE") "\\Desktop"))
    (cons "styleNum" "1")
    (cons "paperNum" "1")
    (cons "scaleStr" "")
  (setq f (open (BPDF-cfgpath) "r"))
  (if f
      (while (setq line (read-line f))
        (setq kv (vl-string-search "=" line))
        (if kv
          (setq cfg (subst
            (cons (substr line 1 kv) (substr line (+ kv 2)))
            (assoc (substr line 1 kv) cfg)
            cfg
      (close f)
  cfg
(defun BPDF-save-cfg (blockname prefix outpath styleNum paperNum scaleStr / f)
  (setq f (open (BPDF-cfgpath) "w"))
  (if f
      (write-line (strcat "blockname=" blockname) f)
      (write-line (strcat "prefix=" prefix) f)
      (write-line (strcat "outpath=" outpath) f)
      (write-line (strcat "styleNum=" (itoa styleNum)) f)
      (write-line (strcat "paperNum=" (itoa paperNum)) f)
      (write-line (strcat "scaleStr=" scaleStr) f)
      (close f)
(defun c:BPDF ( / blockname outpath ss i ent obj sel entdata plotMode
                  minpoint maxpoint pt1 pt2
                  counter fname adoc alayout aplot
                  scaleStr scaleVal useFit styleSheet
                  prefix frameList frame fx fy fx2 fy2 rowHeight
                  plotterName styleList styleNum
                  allMedia mediaShort mediaIdx m j item
                  paperNum paperSize cfg lastVal inp confirm
                  AC_WINDOW err)
  (vl-load-com)
  (setq cfg (BPDF-load-cfg))
  ;; 1. Click to select title block, or type name
  (princ "\nClick on a title block frame (or press Enter to type block name): ")
  (setq sel (entsel ""))
  (if sel
      (setq ent (car sel))
      (setq entdata (entget ent))
      (if (= (cdr (assoc 0 entdata)) "INSERT")
          (setq blockname (cdr (assoc 2 entdata)))
          (princ (strcat "\nBlock detected: " blockname "\n"))
          (initget "1 A")
          (setq plotMode
            (getkword "\nPlot [1=This frame only / A=All frames with this name] <A>: ")
          (if (null plotMode) (setq plotMode "A"))
          (alert "Please click on a Block (INSERT) entity.")
          (exit)
      (setq lastVal (cdr (assoc "blockname" cfg)))
      (if (/= lastVal "")
        (setq inp (getstring (strcat "\nBlock Name <" lastVal ">: ")))
        (setq inp (getstring "\nBlock Name: "))
      (setq blockname (if (= inp "") lastVal inp))
      (if (= blockname "") (progn (princ "\nCancelled.") (exit)))
      (setq plotMode "A")
  ;; 2. PDF Prefix
  (setq lastVal (cdr (assoc "prefix" cfg)))
  (setq inp (getstring (strcat "\nPDF Prefix <" lastVal ">: ")))
  (setq prefix (if (= inp "") lastVal inp))
  ;; 3. Output Folder
  (setq lastVal (cdr (assoc "outpath" cfg)))
  (setq inp (getstring (strcat "\nOutput Folder <" lastVal ">: ")))
  (setq outpath (if (= inp "") lastVal inp))
  (if (/= (substr outpath (strlen outpath)) "\\")
    (setq outpath (strcat outpath "\\"))
  (vl-mkdir outpath)
  (princ (strcat "Output: " outpath "\n"))
  ;; 4. Build frame list
  (if (= plotMode "1")
      ;; Single mode: get bbox of the clicked entity directly
      (setq obj (vlax-ename->vla-object ent))
      (vla-getboundingbox obj 'minpoint 'maxpoint)
      (setq frameList (list (list
        (vlax-safearray-get-element minpoint 0)
        (vlax-safearray-get-element minpoint 1)
        (vlax-safearray-get-element maxpoint 0)
        (vlax-safearray-get-element maxpoint 1)
      (setq counter 1)
      (princ "Mode: Single frame\n")
      ;; All mode: find all matching blocks
      (setq ss (ssget "X"
        (list (cons 0 "INSERT") (cons 2 blockname) (cons 410 "Model"))
      (if (null ss)
        (progn (alert (strcat "Block not found: " blockname)) (exit))
      (setq counter (sslength ss))
      (setq frameList nil i 0)
      (repeat counter
        (setq ent (ssname ss i))
        (setq fx (vlax-safearray-get-element minpoint 0))
        (setq fy (vlax-safearray-get-element minpoint 1))
        (setq fx2 (vlax-safearray-get-element maxpoint 0))
        (setq fy2 (vlax-safearray-get-element maxpoint 1))
        (setq frameList (append frameList (list (list fx fy fx2 fy2))))
        (setq i (1+ i))
      ;; Sort: top-to-bottom rows, left-to-right within row
      (setq rowHeight (* (- (cadddr (car frameList)) (cadr (car frameList))) 0.5))
      (setq frameList
        (vl-sort frameList
          (function (lambda (a b)
            (if (> (abs (- (cadr a) (cadr b))) rowHeight)
              (> (cadr a) (cadr b))
              (< (car a) (car b))
      (princ (strcat "Mode: All frames (" (itoa counter) " found)\n"))
  ;; 5. VLA setup
  ;;    Fix from forum: RefreshPlotDeviceInfo BEFORE ConfigName,
  ;;    then ConfigName, then RefreshPlotDeviceInfo again.
  ;;    This prevents "Invalid input" on fresh CAD sessions.
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq alayout (vla-get-activelayout adoc))
  (setq aplot (vla-get-plot adoc))
  (setq plotterName "DWG To PDF.pc3")
  (vla-RefreshPlotDeviceInfo alayout)
  (vla-put-configname alayout plotterName)
  ;; Detect AC_WINDOW value: try 4 first (works on more setups),
  ;; fall back to 3 only if 4 is rejected.
  ;; Note: plottype=3 can silently "accept" but not actually work.
  (setq AC_WINDOW 4)
  (setq err (vl-catch-all-apply
    (function (lambda () (vla-put-plottype alayout 4)))
  (if (vl-catch-all-error-p err)
      (vla-put-plottype alayout 3)
      (setq AC_WINDOW 3)
  ;; 6. Plot Style
  (setq styleList
    (vlax-safearray->list
      (vlax-variant-value (vla-GetPlotStyleTableNames alayout))
  (setq styleList (append (list "None (Color)") styleList))
  (setq lastVal (atoi (cdr (assoc "styleNum" cfg))))
  (if (or (< lastVal 1) (> lastVal (length styleList))) (setq lastVal 1))
  (princ "\nPlot Style:\n")
  (setq i 1)
  (foreach s styleList
    (princ (strcat "  " (itoa i) ". " s (if (= i lastVal) "  <- last" "") "\n"))
    (setq i (1+ i))
  (setq inp (getint (strcat "Select <" (itoa lastVal) ">: ")))
  (setq styleNum (if (or (null inp) (< inp 1) (> inp (length styleList))) lastVal inp))
  (setq styleSheet (if (= styleNum 1) "" (nth (1- styleNum) styleList)))
  (princ (strcat "Style: " (if (= styleSheet "") "None" styleSheet) "\n"))
  ;; 7. Paper Size
  (setq allMedia
      (vlax-variant-value (vla-GetCanonicalMediaNames alayout))
  (setq mediaShort nil mediaIdx 0)
  (foreach m allMedia
    (if (or (vl-string-search "A0" m) (vl-string-search "A1" m)
            (vl-string-search "A2" m) (vl-string-search "A3" m)
            (vl-string-search "A4" m))
      (setq mediaShort (append mediaShort (list (list mediaIdx m))))
    (setq mediaIdx (1+ mediaIdx))
  (setq lastVal (atoi (cdr (assoc "paperNum" cfg))))
  (if (or (< lastVal 1) (> lastVal (length mediaShort))) (setq lastVal 1))
  (princ "\nPaper Size:\n")
  (setq j 1)
  (foreach item mediaShort
    (princ (strcat "  " (itoa j) ". " (cadr item) (if (= j lastVal) "  <- last" "") "\n"))
    (setq j (1+ j))
  (setq paperNum (if (or (null inp) (< inp 1) (> inp (length mediaShort))) lastVal inp))
  (setq paperSize (cadr (nth (1- paperNum) mediaShort)))
  (princ (strcat "Paper: " paperSize "\n"))
  ;; 8. Scale
  (setq lastVal (cdr (assoc "scaleStr" cfg)))
    (strcat "\nScale denominator (100=1:100, 0 or F=Fit, Enter=last setting)"
      (if (/= lastVal "") (strcat " <" lastVal ">") " <Fit>") ": ")
  (setq scaleStr (if (= inp "") lastVal inp))
  ;; 0 or F or empty = Fit to paper
  (if (or (= scaleStr "")
          (= scaleStr "0")
          (= (strcase scaleStr) "F")
          (= (strcase scaleStr) "FIT"))
    (progn (setq useFit T scaleVal 0) (setq scaleStr ""))
    (setq useFit nil scaleVal (atof scaleStr))
  (BPDF-save-cfg blockname prefix outpath styleNum paperNum scaleStr)
  ;; 9. Apply plot settings ONCE before loop (not inside loop!)
  (setvar "BACKGROUNDPLOT" 0)
  (vla-put-canonicalmedianame alayout paperSize)
  (vla-put-plotrotation alayout AC_0DEG)
  (vla-put-centerplot alayout :vlax-true)
  (vla-put-plotwithlineweights alayout :vlax-true)
  (if (/= styleSheet "")
      (vla-put-plotwithplotstyles alayout :vlax-true)
      (vla-put-stylesheet alayout styleSheet)
    (vla-put-plotwithplotstyles alayout :vlax-false)
  (if useFit
      (vla-put-useStandardScale alayout :vlax-true)
      (vla-put-standardscale alayout AC_FIT)
      (vla-put-useStandardScale alayout :vlax-false)
      (vla-SetCustomScale alayout 1.0 scaleVal)
  ;; 10. Confirm
  (alert (strcat
    "===== Confirm Plot =====\n\n"
    "Frames: " (itoa counter) "\n"
    "Prefix: " prefix "\n"
    "Scale:  " (if useFit "Fit" (strcat "1:" (rtos scaleVal 2 0))) "\n\n"
    "Click OK to continue"
  (initget "Y N")
  (setq confirm (getkword "\nConfirm [Y=Yes / N=Cancel] <Y>: "))
  (if (= confirm "N")
  ;; 11. Plot loop
  ;;     SetWindowToPlot THEN put-plottype (per Autodesk docs)
  ;;     No RefreshPlotDeviceInfo inside the loop (that was breaking it)
  (princ "Plotting...\n")
  (setq i 0)
  (foreach frame frameList
    (setq pt1 (vlax-make-safearray vlax-vbdouble '(0 . 1)))
    (vlax-safearray-put-element pt1 0 (car frame))
    (vlax-safearray-put-element pt1 1 (cadr frame))
    (setq pt2 (vlax-make-safearray vlax-vbdouble '(0 . 1)))
    (vlax-safearray-put-element pt2 0 (caddr frame))
    (vlax-safearray-put-element pt2 1 (cadddr frame))
    (vla-SetWindowToPlot alayout pt1 pt2)
    (vla-put-plottype alayout AC_WINDOW)
    (setq fname (strcat outpath prefix "_" (itoa (1+ i)) ".pdf"))
    (vla-PlotToFile aplot fname)
    (princ (strcat "  [" (itoa (1+ i)) "/" (itoa counter) "] Done\n"))
    (setq i (1+ i))
  (setvar "BACKGROUNDPLOT" 2)
  (alert (strcat "Done! " (itoa counter) " PDFs exported\nLocation: " outpath))
GitHub link with README and installation instructions:
Happy to answer any questions!
Edited by Beastt1992
Thanks Steven! Code is posted above.
Regarding Paper Space - completely agree it's
the better long-term approach, but changing an
entire office workflow is harder than writing
a tool to work around it!
My 0.02¢
Instead of outputting the status to command line
Output to the Status Bar
(setvar "MODEMACRO" (strcat "Processing: [" (itoa (1+ i)) "/" (itoa counter) "] Layouts"))
Then you don't have clutter/spam in the command prompt but still have the current stats. Just have to clear it after complete.
1 hour ago, mhupp said:
My 0.02¢
That's a great tip, thank you! Much cleaner than spamming the command line. I'll add this to the next version and clear the status bar when done.
Welcome to Cadtutor. What you are offering is not a new solutions this have been around for me say 17 years, for where I worked.
But I have something extra for you, once you make the PDF's as single pdf's you can join them back into one, done this for 88 layouts but code looks for PDF's. It uses Ghostscript to rejoin the pdf's. Ghostscript is a free product and has lots of features. The code is ran via lisp.
The code attached also allows for a selection of layouts it has the Ghostscript code in it. You will need to edit the version of Ghostscript and its location.
A more advanced version checks for different company title blocks, eg landscape V's portrait.
Like others I would push for using layouts a much better way as you can take advantage of the viewport scale, I have multi code for making multiple  layouts at scale matching your model space.
Multi GETVALS.lsp plotA3Pdfrange2.lsp
Thank you for the welcome and for sharing your code!
You're right that similar tools have existed for a long time - my goal was to create a modern open source version with a dialog box interface that's more accessible to new users.
The Ghostscript PDF merging idea is brilliant - I hadn't thought of that and will look into adding it as an optional feature.
Your version works with Layouts which is the correct workflow. Mine is specifically for the Model Space workflow common in Taiwan/Asia, so they serve different use cases.
Thanks again for the tips!
