[SHARE] SyncBlock - Synchronize specific layers across multiple blocks with precise alignment
Hi everyone,
I want to share a LISP tool I recently developed called SyncBlock.
If you work with architectural or MEP backgrounds, you probably deal with this nightmare constantly: You have a Master Block (A), and several child blocks (B, C, D) that were copied from A but have some layers deleted to show different details. When the Master Block updates, synchronizing those child blocks without ruining their specific layer visibility—and without them flying off to random coordinates because their base points are all set to (0,0,0)—is a huge pain.
To solve this, I wrote a script that does the following:
1. You select the Master Block.
2. You window-select the target blocks.
3. The script reads which layers are currently active in the target block, clears it, and pulls only those matching layers from the Master Block.
The Magic (Consensus Voting Algorithm):
The biggest challenge was alignment. Standard Bounding Box methods fail if you delete half a room or add a dimension in the child block. To fix this, the script uses a "Consensus Voting" approach. It gathers all valid geometry centers in both blocks, pairs them up, calculates the displacement vectors (dX, dY), and lets them "vote." The offset with the overwhelming majority wins. This ensures pixel-perfect alignment even if the child block is heavily trimmed!
GitHub Repository:
https://github.com/beastt1992/SyncBlock-AutoCAD
The code avoids copying Hatches to prevent associativity crashes, and it safely handles older AutoCAD versions (like 2014) by using pure English prompts to avoid ANSI/UTF-8 encoding issues.
I’d love for you guys to test it out on your messy real-world drawings! Any feedback, bug reports, or suggestions for improvement are highly appreciated.
Cheers!
