I am searching for a lisp code to recognizes and dimensions LINE or ARC objects located in the Wall-2D layers and blocks in the CLOSETS-2D layer. like the image
The dimension layer is DIM
The idea is  to pick 2  points like a line and automatic insert the dmensions. I use ZWCAD.
Thanks
Edited by mhy3sx
Yes I have something done like 40 years ago, but did you try QDIM is that in ZWCAD ?
Hi BIGAL, I have try QDIM but  working as
Quote
Select geometry to dimension :
The QDIM don't dimension the block (look the image)
I want to draw a line by specifying two points, to indicate where dimensions should be placed.
This line should only appear on the layers named WALLS-2D and CLOSETS-2D.
The WALLS-2D layer contains both lines and polylines, while the CLOSETS-2D layer contains blocks.
Thanks
Edited by mhy3sx
Drawing the line would also pick up 4 lines across the block. would maybe have to do a fence ssget. and if block draw a bounding box to pick up lines but even then could be inaccurate if not a square.
  • Agree 1
I find a solution. I craete a polyline ,then auto dimension the polyline and delete the polyline. Beter tahn nothing :)
Thanks
