Avoiding Copy and Paste to secure clipboard data progress!
Need someone to get this tool to crash for a test and get me to find solution.
Had this previously using no entmake or trans but seems to work now.
(defun c:4x  (/ *error* pt1 pt2 ss  )
(princ (strcat "\n 45"(chr 186)"/135"(chr 186)" 3D.XLines <!pp>"))
  (defun *error* ( msg )
     (setvar 'cmdecho 0)
   (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
      (if msg (prompt (strcat "\n" msg)))
        (setvar 'cursorsize 100)    ;; reset to my prefer
     (setvar 'cmdecho 1)
  (setvar 'cursorsize 1)
  (entmakex ;;                  <LM
        (000 . "LAYER")
        (100 . "AcDbSymbolTableRecord")
        (100 . "AcDbLayerTableRecord")
        (002 . "XLINE")      ;; Layer Name
        (070 .  0)           ;; Layer Status     (bit-coded)
        (006 . "Continuous") ;; Layer Linetype   (must be loaded)
        (062 .  252)          ;; Layer Colour     (1-255)
        (290 .  0)           ;; Non-Plot Flag    (0=Plot, 1=NoPlot)
        (370 . -3)           ;; Layer Lineweight (-3=Default)
   (defun zPoint ( / exv) ;; 3d point mfg
      (setq pt1 (trans pt1 1 0))
      (setq exv (trans (list 0 0 1) 1 0 T))
      (entmakex (list (cons 0 "POINT")
      (cons 10 pt1)
      (cons 210 exv)))
   (defun cdd ()
      (princ "\n")
        (princ
          (setq pp                               ;;  make/prints coords & paste usable
                  (strcat
                     (rtos (car pt1) 2 4) ","        ;; 'p' -- vertex from pgm /\ getpoint,...
                     (rtos (cadr pt1) 2 4) ","
                     (rtos (caddr pt1) 2 4)
   (princ " cucs ");;    ;   (entmakex (list (cons 0 "POINT") (cons 10 pt))) ;; clean point
  (setenv "pp" pp) ;; crash saved coords
      ;; Get the initial placement point
(while (setq pt1 (getpoint "\nSpecify Point for XLines: "))
(setvar 'cmdecho 0)
      ;; Create a new empty selection set
      (setq ss (ssadd))
      ;; Create horizontal xline and add to selection set
      (command "_.xline" "_a" 45 pt1 "")
      (command "chprop" "_L" "" "la" "XLINE" "") ;; make xline grey
      (ssadd (entlast) ss)
      ;; Create vertical xline and add to selection set
      (command "_.xline" "_a" 135 pt1 "")
     (cdd) ;; post coords
    (zPoint) ;; point at 'pick.point
(setvar 'cmdecho 1)
  ) ;; end of while
Edited by ScottMC
forgot variable..
