Hello,
I working in this environment not possible anymore? I'm on AutoCAD 2025. It seems like working only in VS Studio Code is possible now. I liked the dedicated UI better.
Biggest function I'm missing is the "Load Selection" button. Any way I can do something similar in VS Studio Code?
If I revert back to the older versions, would working in the Visual LISP environment be possible?
9 minutes ago, mhupp said:
Autodesk no longer supports/updates VLIDE and i don't know if its even present in newer versions of autocad.
@mhupp Correct it's no longer supported, but the "VLIDE" command and environment still works, at least as of my AutoCAD 2026.
  • Like 2
Ah that kinda sucks. Guess I'll have to learn the new environment.
IDE had this button to inspect selection, does VS Code have something similar? image.png.9014c1172d0e8196301555fa64acb333.png
Regardless, appreciate the prompt response @mhupp. :)
