G.Aquarius Posted 2 hours ago Posted 2 hours ago Hello, I working in this environment not possible anymore? I'm on AutoCAD 2025. It seems like working only in VS Studio Code is possible now. I liked the dedicated UI better. Biggest function I'm missing is the "Load Selection" button. Any way I can do something similar in VS Studio Code? If I revert back to the older versions, would working in the Visual LISP environment be possible?  Quote
mhupp Posted 1 hour ago Posted 1 hour ago (edited) Autodesk no longer supports/updates VLIDE and i don't know if its even present in newer versions of autocad. Â They want you to use VS code. here is the setup process. https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-7BE00235-5D40-4789-9E34-D57685E83875 Â to get vlide back you would have to roll back to something like 2020 or older. Edited 1 hour ago by mhupp Quote
pkenewell Posted 1 hour ago Posted 1 hour ago 9 minutes ago, mhupp said: Autodesk no longer supports/updates VLIDE and i don't know if its even present in newer versions of autocad. @mhupp Correct it's no longer supported, but the "VLIDE" command and environment still works, at least as of my AutoCAD 2026. 2 Quote
mhupp Posted 1 hour ago Posted 1 hour ago Ah looking it up you have to set the following https://help.autodesk.com/view/ACDLT/2026/ENU/?guid=GUID-1853092D-6E6D-4A06-8956-AD2C3DF203A3 Â (setvar 'LISPSYS 0) Â 1 Quote
G.Aquarius Posted 1 hour ago Author Posted 1 hour ago Ah that kinda sucks. Guess I'll have to learn the new environment.  IDE had this button to inspect selection, does VS Code have something similar?  Regardless, appreciate the prompt response @mhupp.   Quote
pkenewell Posted 1 hour ago Posted 1 hour ago 5 minutes ago, mhupp said: Ah looking it up you have to set the following https://help.autodesk.com/view/ACDLT/2026/ENU/?guid=GUID-1853092D-6E6D-4A06-8956-AD2C3DF203A3  (setvar 'LISPSYS 0)   Oh yes - I forgot about that little detail Quote
G.Aquarius Posted 1 hour ago Author Posted 1 hour ago I didn't read the other responses, changing the value for LISPSYS worked. Thank you @mhupp @pkenewell Quote
