Hello everyone,
I’m trying to create a LISP to help with pipe takeoffs in AutoCAD. Here’s what I want it to do:
I have a plan with pipes of different sizes drawn as lines or polylines.
I want to create a takeoff layer (e.g., "M-TakeOff-CWS").
Instead of redrawing, I just select a line or polyline segment and choose a pipe size.
The code should automatically split the selected segment at all intersections with other lines or polylines.
Each resulting sub-segment is duplicated in place on the takeoff layer.
The duplicated segments get a color based on the chosen size.
The original line or polyline stays intact.
Later, I want to filter by color/size to calculate total lengths.
I’ve tried several approaches, but I’m struggling with:
Splitting segments automatically at intersections.
Duplicating them on a new layer.
Assigning colors by size.
Does anyone have a simple LISP example or guidance for this workflow?
Thanks in advance!
Can you upload an example *.dwg file please to see how we can help.
Welcome aboard.
Yes need a sample dwg showing a before and after, breaking at intersections various examples are out there.
When asking for help you nearly always should provide a sample dwg or some images.
