Lisp program to paste to multiple reference point inside cad.
I want to create an AutoLISP file that can paste objects to multiple reference points within a CAD file.
I have a sample generated by GPT that works, but the problem is that I have to hardcode the reference point inside the LISP code every time.
I need to modify it so that I can define the base point manually within CAD instead.
See the reference and suggest the solution
(defun c:PASTEPOINT ( / choice basept)
;; Define your reference points for each floor
;; Replace the coordinates with your actual base points
(setq basement '(0 0 0))
(setq ground '(1000 0 0))
(setq first '(2000 0 0))
;; Ask user which floor to paste into
(setq choice
(strcase
(getstring "\nPaste to which floor? [Basement/Ground/First]: ")
;; Select base point based on user choice
(cond
((= choice "BASEMENT") (setq basept basement))
((= choice "GROUND") (setq basept ground))
((= choice "FIRST") (setq basept first))
(T (progn
(prompt "\nInvalid option. Use Basement, Ground, or First.")
(exit)
;; Execute paste command at selected base point
(command "_.PASTECLIP" basept)
Edited by SLW210
Added Code Tags!!
Please use Code Tags (not Quote Tags) for your code. (<> in the editor toolbar)
And simply with this, can be done?
(defun c:PASTEPOINT ( / basept)
  (setq basept "Basement")
  (initget 9 "Basement Ground First")
  (while (not (listp basept))
    (setq basept (getpoint (strcat "\nPaste to which floor? [Basement/Ground/First]<" basept ">: ")))
  (command "_.PASTECLIP" "_none" basept)
  (prin1)
I'd be interested in what you prompted to get that code.
GPT score 3/10
- missed localized variables
- hard code points instead of getpoint
- choice doesn't use getkword or use ucase (will only accept all caps input?)
