I don't think so - but maybe this would work (I have made it so that it collects objects from all spaces (I don't think this is an issue, but worth a try).
Also, it sets the UCS after filtering the set.
(defun c:yellowr  (/ oldosn ss)
 (setq oldosn (getvar "osmode"))
 (setvar "osmode" 0)
 (command "UCS" "W")
 (if (setq ss (ssget "X" (list (cons 0 "INSERT"))))
     (foreach ent  (mapcar 'cadr (ssnamex ss))
       (if (not (< (cadddr (assoc 10 (entget ent))) -10))
         (ssdel ent ss)))
     (if (not (zerop (sslength ss)))
         (ucs-sel "yellow")
       (repeat 9
         (command "_rotate" ss "" '(0 0 0) -10)))))
   (princ "\n<!> No Blocks Found <!>"))
 (setvar "osmode" oldosn)
 (princ))
(defun c:redr  (/ oldosn ss)
 (setvar "osmode" 0)
 (command "UCS" "W")
       (if (not (< (caddr (assoc 10 (entget ent))) -10))
         (ssdel ent ss)))
         (ucs-sel "red")
       (repeat 9
 (princ))
(defun ucs-sel  (col)
 (COMMAND "UCS" "NAMED" "R" col))
  • Replies 33
  • Lee Mac
    16
  • Stermaj
    16
  • SEANT
    2
I tried debugging by running (entget (car (entsel))) and selecting random blocks. I discovered that the coordinates for a block after a rotation are:
Select object: ((-1 . ) (0 . "INSERT") (330 .
name: 7ef05cf8>) (5 . "564") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"Side") (62 . 0) (100 . "AcDbBlockReference") (2 . "OR") (10 -27.15 1.2568e-013
27.15) (41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 4.71239) (70 . 0) (71 . 0) (44 .
0.0) (45 . 0.0) (210 1.0 0.0 3.60822e-016))
Now the block i selected was originally at 0,-27.15, 27.15, and it was rotated to 27.15,-27.15,0. For some reason, autocad seems to not think the block is at either location. The coordinates autocad reads now for the block are relative to the rotation of the reducs, but positionally relative to the WCS. I have no idea why this would be the case, but this would be why the later rotation steps fail.
Is there a way to use autolisp to select all objects intersecting a plane? if so, can i just input 6 planes to intersect each face and have that be the criteria to do the rotations instead?
I'm not sure about selecting objects that intersect a plane - but, the
1.2568e-013
is just AutoCADs way of saying zero, so the block has been rotated from:
0,-27.15, 27.15
to
-27.15, 0, 27.15
The points listed in the DXF tables are ALWAYS in WCS.
Even with accounting for 1.2568e-013 being 0, the entget function still reads
-27.15 .2568e-013 27.15 even though the block is at 27.15,-27.15,0. The XYZ coordinates are mixed up, the actual z position is 0, while autocad thinks its 27.15, the y position is -27.15 but autocad thinks its 0, and the x is listed at -27.15 instead of +27.15
Are you sure that the position you are seeing isn't a UCS position, whereas the position that (entget) reads is WCS?
Yes. I reset the UCS to the WCS to try to see if that was the case. the lisp program works as it should, but autocad for some reason is reporting the wrong locations for these blocks. Im going to try it on another computer to see if its a local problem or not.
It was the same on the other computer. I decided to redo the whole code and instantly set the view to a side view, then run
ssget "w" with coordinates to select a box that encompasses a side, then flip back to the original view and then perform the rotation there. Its simpler but for a split second you see the screen change views. Thanks again though for all your help!
-Jon
(defun c:greenr (/ oldosn)
(setvar "osmode" 0)
(COMMAND "UCS" "W")
(COMMAND "-view" "S" "tempview")
(COMMAND "-view" "O" "Front")
(setq ss (ssget "C" '(-20 0 30) '(-30 0 -30)))
(COMMAND "-view" "Restore" "tempview")
(c:greenucs)
(repeat 18
(COMMAND "_rotate" ss "" '(0 0 0) -5)
(COMMAND "UCS" "W")
yeah, me too. Thanks again though for all your time.
For what it’s worth, some objects (e.g., Inserts, LightWeightPolylines) maintain their own Object Coordinate System (OCS). This coordinate system is not (necessarily) based on either the WCS or current UCS but derived from the objects Extrusion Direction (Normal, or Group code 210). For more information search the DXF Reference for “Arbitrary Axis Algorithm”.
Queries to these objects will be return coordinates based on this OCS. These can be translated to either WCS or UCS with the trans function or ThisDrawing.Utility.TranslateCoordinates method in VBA.
Ahh I see, thanks Sean - so I suppose its worth trying this then:
 (setvar "osmode" 0)
 (command "UCS" "W")
       (if (not (< (caddr ([color=Blue][b]trans[/b][/color] (cdr (assoc 10 (entget ent))) [color=Blue][b]2 0[/b][/color])) -10))
         (ssdel ent ss)))
         (ucs-sel "yellow")
         (repeat 9
 (princ))
 (setvar "osmode" 0)
 (command "UCS" "W")
       (if (not (< (cadr ([b][color=Blue]trans[/color][/b] (cdr (assoc 10 (entget ent))) [color=Blue][b]2 0[/b][/color])) -10))
         (ssdel ent ss)))
         (ucs-sel "red")
         (repeat 9
 (princ))
It could be. . . . I'd have to be quite a bit more familiar with Lisp to say for certain. :unsure:
