MultiPLine (MPL) — polyline-based MLINE replacement with per-line layers, presets, and auto-sync [Free + Pro]
Hi all,
I've been a lurker on CADTutor for years and learned
a lot from this community, so I wanted to share
something I built and get feedback from people who
actually know LISP.
Background: I'm a civil CAD drafter working on US
land development projects — grading, drainage,
easements, corridors. MLINE has always been the
tool I wanted to use for drawing parallel offset
lines but couldn't, mainly because the objects are
locked, there's no lineweight control per component,
and the .mln style management across a team is a
nightmare. So I wrote a replacement.
WHAT IT DOES
Command MPL works like PLINE — you draw a centerline
and it generates a set of configurable parallel
LWPOLYLINEs around it. Every satellite line is a
real polyline: fully grip-editable, trimmable,
offsettable, joinable. No locked geometry, no
exploding required.
Each satellite line carries its own:
- Offset distance (positive = left, negative = right)
- Layer (Pro version)
- Color, linetype, lineweight, linetype scale
Configuration is handled through a DCL dialog
(MPLEDIT). Settings save as user defaults and,
in the Pro version, as named presets stored in
%APPDATA%\MplineAuto\presets.dat.
TWO VERSIONS
Lite (free .lsp):
- MPL, MPLEDIT, MPLSYNC
- Manual sync after edits — run MPLSYNC,
  window-select the group, done
- Groups are tracked via XDATA (app tag: MPLINE_PIPE)
Pro (compiled .vlx, $29.49):
- Everything in Lite plus:
- Command reactor for auto-sync — watches masters
  before/after every command, diffs vertex lists,
  rebuilds only what changed
- Named preset library with Save/Update/Delete
  from the dialog
- Per-satellite layer assignment
- MPLADD — promote existing LWPOLYLINEs or LINEs
  into MPL groups
- MPLON / MPLOFF — toggle reactor at runtime
- XDATA app tag: MPLINE_AUTO
IMPLEMENTATION NOTES
The interesting part was the Pro reactor. I went
through a few approaches before landing on a global
command reactor that snapshots the master cache
before a command fires and diffs it after. This
avoids object reactors entirely (which caused IDispatch
arity issues in testing) and means the reactor
doesn't interfere with Express Tools or COPY/MIRROR
operations on non-MPL geometry.
Groups copied with COPY or MIRROR produce new masters
on the next MPLSYNC call — the reactor doesn't
auto-register copies, which is intentional to avoid
unexpected geometry multiplication.
Happy to discuss the approach if anyone has thoughts
or has solved similar problems differently.
LINKS
Video walkthrough: https://youtu.be/DXpyy1JWtXs
Free Lite download:
https://skillamplifier.gumroad.com/l/hgpujs
Pro listing:
https://skillamplifier.gumroad.com/l/nsidsv
Blog post with full documentation and use cases:
https://skillamplifier.wordpress.com/2026/05/16/multipline/
Full disclosure: I'm the developer. Posting here
because I'd genuinely value feedback from experienced
LISP users, and the Lite version is free so there's
no risk trying it.
Thanks for any thoughts.
Zlatislav
Just a couple of comments have this, type 2,4,-3,-4 and so on, draws multiple plines, as many as you type in one go.. Have a drag line over existing multi offsets and get all offsets and layers, so can make another pline without user input.
Also what about Bricscad users ? Plenty of us here as well as other software.
Oh yeah look at this image you draw a "WALL" that is multiple lines and on correct layers, predefined layers that are named in a txt file, so match what a user wants without editing code, won't go into how we made that work other than variable = layer name.
Not sure that the task really warrants a VLX and a cost when there is software out there for the task and its free. I know from experience trying to sell software is extremely hard, as per draw house program some 130 lisps.
Do you have something similar to the attached DOCX, showing what you have as say a package, most programs are free and open source some have a cost as need to be customised for clients. There is more scope for users to buy a package rather than just one program.
Lisp files DEC 2025.docx
Edited by BIGAL
Thanks both for the honest feedback — exactly what I was hoping for.
@pkenewell — appreciate the link, I'm aware of Lee Mac's MPLine and have a lot of respect for his work. His implementation is elegant and handles the core offset drawing well. MultiPLine goes in a different direction: DCL-based configuration dialog, per-line layer assignment, named presets that persist across drawings, and the Pro version adds a command reactor for auto-sync. Different scope rather than a direct replacement for what he built. Worth knowing about either way so thanks for flagging it.
@BIGAL — fair points across the board. BricsCAD: honestly didn't design for it and can't make promises there. The reactor implementation in Pro leans on AutoCAD-specific VLR functions. Lite might load fine in BricsCAD but I haven't tested it — if any BricsCAD users try it I'd be curious to hear the result. On the "why pay" question: fair challenge. The free Lite version covers the core workflow for most users. The Pro is aimed at teams and daily-driver users who want auto-sync and a preset library they can share across a team. Whether that's worth $29 is genuinely up to the buyer — I'm not trying to oversell it. The package suggestion is actually something I've been thinking about. MultiPLine is my first commercial release but I have other tools in progress. A bundle makes more sense as a value proposition and I'll keep that in mind for when there's more to package together.
One more thing — I've added the full .lsp source to the Lite download on Gumroad. Free to inspect, modify for personal use, and learn from.
Thanks again for taking the time — this kind of feedback from experienced users is more useful than any marketing.
Zlatislav
Taking your example video this is convert a p/line to a drainage pipe written for civil road works, with most common AUS sizes. Needs linetype Equal the length of dashed is set to 2.4 which is a length of a concrete pipe. Handy for civil works. It is not dynamic.
*EQUAL,_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
A,1.0,-1.0
Pipe offsets.lsp
If you post here a VLR function can test.
Fillet offset circle.lsp
Have a look at "Fillet offset circle" uses reactors.
@BIGAL — the Pipe offsets approach is practical — hardcoded OD values per size as named commands (P300, P450 etc) is exactly the kind of thing that saves time on repetitive civil work. Applies the offset and switches to Divide linetype in one shot. Clean for a site-specific workflow.
The Fillet offset circle reactor is a nice trick — using :vlr-unknowncommand to intercept custom prefixed strings like F100 or O234 is a different approach than what I went with. Avoids the willstart/ended pair entirely by hooking into unrecognised input instead.
Here's the core VLR setup from the Pro version
for comparison:
(vlr-command-reactor
  nil
  '((:vlr-commandWillStart . mpla-on-cmd-willstart)
    (:vlr-commandEnded     . mpla-on-cmd-ended)
    (:vlr-commandCancelled . mpla-on-cmd-cancel)
    (:vlr-commandFailed    . mpla-on-cmd-cancel))
The willstart handler snapshots vertex lists and widths of all MPL masters into a global cache (*mpla-master-cache*). The ended handler diffs and rebuilds only the groups that changed. Went this route to watch standard commands passively without requiring any special input syntax.
Happy to share more if useful.
