MultiPLine (MPL) — polyline-based MLINE replacement with per-line layers, presets, and auto-sync [Free + Pro]
Hi all,
I've been a lurker on CADTutor for years and learned
a lot from this community, so I wanted to share
something I built and get feedback from people who
actually know LISP.
Background: I'm a civil CAD drafter working on US
land development projects — grading, drainage,
easements, corridors. MLINE has always been the
tool I wanted to use for drawing parallel offset
lines but couldn't, mainly because the objects are
locked, there's no lineweight control per component,
and the .mln style management across a team is a
nightmare. So I wrote a replacement.
WHAT IT DOES
Command MPL works like PLINE — you draw a centerline
and it generates a set of configurable parallel
LWPOLYLINEs around it. Every satellite line is a
real polyline: fully grip-editable, trimmable,
offsettable, joinable. No locked geometry, no
exploding required.
Each satellite line carries its own:
- Offset distance (positive = left, negative = right)
- Layer (Pro version)
- Color, linetype, lineweight, linetype scale
Configuration is handled through a DCL dialog
(MPLEDIT). Settings save as user defaults and,
in the Pro version, as named presets stored in
%APPDATA%\MplineAuto\presets.dat.
TWO VERSIONS
Lite (free .lsp):
- MPL, MPLEDIT, MPLSYNC
- Manual sync after edits — run MPLSYNC,
  window-select the group, done
- Groups are tracked via XDATA (app tag: MPLINE_PIPE)
Pro (compiled .vlx, $29.49):
- Everything in Lite plus:
- Command reactor for auto-sync — watches masters
  before/after every command, diffs vertex lists,
  rebuilds only what changed
- Named preset library with Save/Update/Delete
  from the dialog
- Per-satellite layer assignment
- MPLADD — promote existing LWPOLYLINEs or LINEs
  into MPL groups
- MPLON / MPLOFF — toggle reactor at runtime
- XDATA app tag: MPLINE_AUTO
IMPLEMENTATION NOTES
The interesting part was the Pro reactor. I went
through a few approaches before landing on a global
command reactor that snapshots the master cache
before a command fires and diffs it after. This
avoids object reactors entirely (which caused IDispatch
arity issues in testing) and means the reactor
doesn't interfere with Express Tools or COPY/MIRROR
operations on non-MPL geometry.
Groups copied with COPY or MIRROR produce new masters
on the next MPLSYNC call — the reactor doesn't
auto-register copies, which is intentional to avoid
unexpected geometry multiplication.
Happy to discuss the approach if anyone has thoughts
or has solved similar problems differently.
LINKS
Video walkthrough: https://youtu.be/DXpyy1JWtXs
Free Lite download:
https://skillamplifier.gumroad.com/l/hgpujs
Pro listing:
https://skillamplifier.gumroad.com/l/nsidsv
Blog post with full documentation and use cases:
https://skillamplifier.wordpress.com/2026/05/16/multipline/
Full disclosure: I'm the developer. Posting here
because I'd genuinely value feedback from experienced
LISP users, and the Lite version is free so there's
no risk trying it.
Thanks for any thoughts.
Zlatislav
