TurboPlot v1.1: Standalone, Multi-threaded Batch Plotter (Auto-detects Frames!)
Hi everyone,
If you are dealing with hundreds of DWG files daily, you probably know the pain of traditional batch plotting tools: AutoCAD freezes up, memory leaks cause crashes, and worst of all—because it plots so slowly, other people's print jobs often get mixed into your batch on the shared office printer!
I’ve developed a standalone software called TurboPlot (v1.1) to solve this exact nightmare, especially when you are on a tight deadline and need your drawings printed instantly.
Unlike standard LISP or .NET add-ins that use the slow ActiveX/COM interface, TurboPlot runs completely independently outside of AutoCAD. It utilizes a highly optimized background engine with True Multi-threading, meaning it plots your drawings silently at blazing speeds while you continue working on other things.
🎥 See it in action:
I've recorded a short video demonstrating how it works. Check it out here: [Insert your YouTube Link here]
🔥 Key Features & Problem Solvers:
No More Interleaved Print Jobs: TurboPlot compiles all your drawings into one single merged PDF before sending it to your physical printer as ONE continuous print job. Your batch stays perfectly together—nobody else in the office can interrupt your print queue again!
Built for Rush Jobs (True Multi-threading): When you need drawings urgently, you can't afford to watch AutoCAD slowly open and close each file. TurboPlot plots 4, 8, or 16 DWGs simultaneously in the background. It gets the job done in a fraction of the time with zero freezing.
Smart Frame Auto-Detection (Game Changer!): You don't need to specify a block name anymore! Leave the name field blank, and TurboPlot will automatically scan the Model or Layout, calculate areas, and instantly find the Largest Frames (whether they are Blocks or closed Polylines) to plot.
Multiple Plot Modes:
By Block Name: Type your title block name(s) (supports multiple names separated by commas) with a history dropdown.
By Layout: Auto-detects and plots all frames within your layouts.
Model Extents.
PDF Management: Automatically merges hundreds of plots into a single neat PDF, OR saves them as individual PDFs next to the original DWG (with _001, _002 suffixes).
No NETLOAD Required: It’s a standalone Windows App. Just open it, drag and drop your DWGs, choose your CTB/Paper Size, and hit run.
Multilingual UI: English, Spanish, Portuguese, Chinese, Japanese, Korean, and Vietnamese.
🛠️ Why is it faster & more stable?
Because it processes your files in the background without loading the heavy AutoCAD GUI, Ribbons, or Workspaces. It silently grabs the exact Bounding Boxes of your frames and plots them flawlessly (with built-in edge-protection margins so your borders never get cut off).
If you are interested in testing it out or saving hours of plotting time every week, let me know or drop a comment below! I'd love to hear feedback from the community.
https://www.youtube.com/watch?v=O-ZZ53UuKFQ
Download link
https://drive.google.com/file/d/14Cn911glapa3nTSigD1srU7LKOHjarz5/view
A lot of us here are using Bricscad so the Acad Accoreconsole is not usable, have you looked at something similar for Bricscad ? Plus others using Gwstar and Intellicad to mention a couple more.
