VS Code + AutoCAD Lisp Extension Issues (Need constant re-starts)
I have this Issue with in VSCode where I'm forced to constantly restart both applications in order to continue debugging.
My Setup: AutoCAD Map3d 2021
VS Code 1.27.0 + Autocad AutoLISP Extension 1.6.3
VSCode Extitions Setup: Process name = acad
AutoCAD com…start switchs: C:\Program Files\Autodesk\AutoCAD 2021\acad.exe
Absolute path: C:\Program Files\Autodesk\AutoCAD 2021\acad.exe
I start Autocad First, then run vlide from the command prompt to load the the VScode application.
Then typical open a lisp project containing multiple lisp files.
Then to start debugging by Pressing “F5”.
Some times this works fine but more often than not I need to restart both app multiple times..
This happens mostly after I run into a code error… like typo or syntax error or trying to load a file autocad cant find.  The only way to be able to continue debugging my project is to completely restart both vscode and autocad(once or a few times).
I seen this with my previous setup as well (different hardware, os and applications versions).
Any idea or suggestion why this could be happening?
Did you read the instructions for the AutoCAD AutoLISP extension?
I run code with AutoCAD, which is the path you show using, that probably doesn't work with AutoCAD Map3D, so you might need to repath if that's the program you use or just use AutoCAD and see if that resolves the issue.
From AutoCAD AutoLISP Extension - Visual Studio Marketplace
Quote
For AutoCAD specialized toolsets or OEM-based products, the product name might not be the same as AutoCAD or acad.exe. To use this extension with those products, set the value of the "Launch Program" attribute in extension setting based on the product you want to debug with.
