CamDuy Posted Friday at 09:05 AM Posted Friday at 09:05 AM Hello everyone, I've just finished developing MPL (Multi Plot Layout/Model), a free AutoLISP tool that helps you batch print drawings in AutoCAD. Main Features MPL includes all the essential functions found in other batch plotting LISP tools, plus several improvements: Smart and intuitive DCL interface Merge all plots into a single PDF (no additional software or virtual PDF printer required) Automatically open the output file or folder after plotting, with customizable file name and save location Zone-based plotting – organize messy drawings and print them in the correct order based on defined zones Batch plot multiple layouts – rearrange the printing order of layout tabs without dragging the tabs at the bottom of AutoCAD Print Preview mode Add Selection feature – easily add more drawings to the current print list without starting over Export/Import plot configuration for quick reuse Download and user guide: https://drive.google.com/drive/folders/1WwmkXVgHFWTy8zIhARJYCH_G2OC2A_3D?usp=sharing Feel free to download it, give it a try, and let me know your feedback. Your suggestions will help improve MPL even further! 2 Quote
rlx Posted Friday at 05:40 PM Posted Friday at 05:40 PM (edited) Welcome to CadTutor CamDuy and thank you for sharing your program, looks like you put a lot of effort in this. The world (and this site) needs more people like you Edited Friday at 07:24 PM by rlx ps. MPL or CAMDUY not working Quote
CamDuy Posted Friday at 10:56 PM Author Posted Friday at 10:56 PM (edited) 13 hours ago, CamDuy said: Xin chào tất cả mọi người, Tôi vừa hoàn thành việc phát triển MPL (Multi Plot Layout/Model), một công cụ AutoLISP miễn phí giúp bạn in hàng loạt bản vẽ trong AutoCAD. Các tính năng chính MPL bao gồm tất cả các chức năng thiết yếu có trong các công cụ vẽ đồ thị hàng loạt LISP khác, cộng thêm một số cải tiến: Giao diện DCL thông minh và trực quan Ghép tất cả các biểu đồ thành một tệp PDF duy nhất (không cần phần mềm bổ sung hoặc máy in PDF ảo). Tự động mở tệp hoặc thư mục đầu ra sau khi vẽ đồ thị, với tên tệp và vị trí lưu có thể tùy chỉnh. In ấn theo vùng – sắp xếp các bản vẽ lộn xộn và in chúng theo đúng thứ tự dựa trên các vùng đã xác định. In hàng loạt nhiều bố cục – sắp xếp lại thứ tự in của các tab bố cục mà không cần kéo các tab ở cuối AutoCAD. Chế độ xem trước khi in Tính năng Thêm lựa chọn – dễ dàng thêm nhiều bản vẽ vào danh sách in hiện tại mà không cần bắt đầu lại từ đầu. Xuất/nhập cấu hình đồ thị để sử dụng lại nhanh chóng Download and user guide: https://drive.google.com/drive/folders/1WwmkXVgHFWTy8zIhARJYCH_G2OC2A_3D?usp=sharing Feel free to download it, give it a try, and let me know your feedback. Your suggestions will help improve MPL even further! download: https://www.vedacad.com/ type code: A7CEHQ Drawing test MPL: https://drive.google.com/file/d/1WgMLRDxaiLchbshI3o_f3WHrV7rHX03e/view?usp=sharing AutoCAD: https://shrinkme.click/Multi_Plot_MPL BricsCAD: https://shrinkme.click/Multi_Plot_MPL_BricsCAD ZwCAD: https://shrinkme.click/Multi_Plot_MPL_ZwCAD Edited Friday at 11:00 PM by CamDuy 1 Quote
VicoWang Posted 13 hours ago Posted 13 hours ago I tried using it with VedaCAD, and it didn't work in 2014 but ran perfectly in 2022. I thought it was a problem with the VedaCAD proxy, so I loaded the VLX file from the cache separately, and it still didn't work in 2014 but could run in 2022. Does this plugin have a minimum version requirement? Quote
Nikon Posted 10 hours ago Posted 10 hours ago On 7/25/2026 at 1:56 AM, CamDuy said: AutoCAD: https://shrinkme.click/Multi_Plot_MPL The link doesn't work for me, could you please attach the archive? Quote
CamDuy Posted 10 hours ago Author Posted 10 hours ago 3 hours ago, VicoWang said: I tried using it with VedaCAD, and it didn't work in 2014 but ran perfectly in 2022. I thought it was a problem with the VedaCAD proxy, so I loaded the VLX file from the cache separately, and it still didn't work in 2014 but could run in 2022. Does this plugin have a minimum version requirement? I think AutoCAD 2014 is too old; versions from 2015 onwards work just fine. because it was built on a higher version. Quote
CamDuy Posted 10 hours ago Author Posted 10 hours ago 12 minutes ago, Nikon said: The link doesn't work for me, could you please attach the archive? Drop me an email "phantrongduybn@gmail.com" I'll send it to you. Quote
VicoWang Posted 10 hours ago Posted 10 hours ago 1 minute ago, CamDuy said: I think AutoCAD 2014 is too old; versions from 2015 onwards work just fine. because it was built on a higher version. When I develop vedacad, it is different. My main coding and compilation are done on 2006, avoiding the use of advanced features and ensuring that vedacad can punch through all versions of 2026 from 2006. However, it is true that most people have already done their daily work on the higher version. My test environment is 2006,2014 and 2022. Quote
CamDuy Posted 10 hours ago Author Posted 10 hours ago 1 minute ago, VicoWang said: When I develop vedacad, it is different. My main coding and compilation are done on 2006, avoiding the use of advanced features and ensuring that vedacad can punch through all versions of 2026 from 2006. However, it is true that most people have already done their daily work on the higher version. My test environment is 2006,2014 and 2022. Thank you for your feedback. I will update the version for 2014 and earlier. Quote
BIGAL Posted 1 hour ago Posted 1 hour ago Just a comment one option I did not see is a plot range I have a simple plot lisp it asks for start layout and end layout handy to plot one or more. Perhaps even 1-2,7-8,12 plots multiple layouts as suggested. Also what about Bricscad version it has BRX not ARX. Quote
