VicoWang Posted 2 hours ago Posted 2 hours ago (edited) Hi everyone, I've been thinking about the "AI taking over" discussion. Personally, I sit in the "Skeptical Co-Pilot" camp. I use LLMs, but natural language is too loose for CAD. I was trying to solve a very pragmatic problem: How do we get an LLM to generate hyper-precise CAD geometry without eating up a million tokens and spitting out hallucinated garbage? Natural language just doesn't cut it for drafting. So, I worked with an AI to invent a prototype "Universal Morphological Matrix" (I just call it V-Code). The idea was to reduce CAD commands down to an absolute, 256-token hex-based root system utilizing Reverse Polish Notation (RPN). (Full disclosure: I'm an architect, not a compiler engineer—I actually had to get the AI to explain what an RPN stack machine even was during our brainstorming sessions). For example, to draw a 10x10x10 box, place a radius 6 sphere at its center, and subtract it, the LLM only needs to output exactly 7 tokens: 10,10,10 ᖴ ᙶ 6 ᖴ ᙺ ᗣ (The ᖴ rune takes a comma-separated stream like 10,10,10 and unpacks it into 3 scalars on the stack. No syntax to hallucinate.) To show how this executes without needing API keys, I wrote an interactive, 3-step DCL sandbox in pure AutoLISP. It walks through the prompt, the V-Code payload, the RPN stack trace, and actually draws the CSG solid. (Runs on 2007+). ;;;----------------------------------------------------------------------------;;; V-Agent Interactive Sandbox v1.0(张量流解码版);;; 架构:使用SIMD进行LLM优化的形态RPN解析;;;兼容性:AutoCAD 2007+(原生Unicode渲染);;; 作者:Vico;;;----------------------------------------------------------------------------(vl-load-com);; --- 核心实用工具 ---(defun VA:分裂(str del / pos)(如果(setq pos(vl-string-search del str))(缺点(substr str 1 pos)(VA:分裂(substr str(+ pos 1(strlen del)))del))(列表str)));; --- 虚拟机和CSG引擎 ---(defun VA:RunVCode(code_str / doc ms stack push pop-val tkns tkn h w l r pt o1 o2 obj raw sub-tkns st)(setq doc(vla-get-ActiveDocument(vlax-get-acad-object))女士(vla-get-ModelSpace文档)堆积零)(defun推(val)(setq stack(cons val stack)))(defun pop-val(/ v)(if stack(progn(setq v(car stack)stack(cdr stack)v)nil)(setq tkns(VA:Split code_str " "))(foreach tkn tkns(如果(/= tkn“”)(控制;; \U+15B4 [Bqb] : 文本流解标(弹出张量字符串->解包->推送标量)((wcmatch tkn "*\U+15B4*")(setq raw(pop-val))(如果原始的(progn;; SIMD解压缩:用逗号分割维度向量(setq sub-tkns(VA:Split(vl-princ-to-string raw)“,”))(foreach st sub-tkns(推(atof st))))));; \U+1676 [Tot] : BOX (Pop H, W, L)((wcmatch tkn "*\U+1676*")(setq h(pop-val)w(pop-val)l(pop-val)pt(vlax-3d-point 0 0 0))(如果(不是(vl-catch-all-error-p(setq obj(vl-catch-all-apply 'vla-addbox(list ms pt l w h))))))(推 obj));; \U+167A [Kok] : 球(流行半径)((wcmatch tkn "*\U+167A*")(setq r(pop-val)pt(vlax-3d-point 0 0 0))(如果(不是(vl-catch-all-error-p(setq obj(vl-catch-all-apply 'vla-addsphere(list ms pt r)))))(推送obj)));; \U+15E3 [Nan] : 减法(Pop Obj2,Obj1 -> Obj1 - Obj2)((wcmatch tkn "*\U+15E3*")(setq o2(pop-val)o1(pop-val))(如果(和o1 o2)(vl-catch-all-apply 'vla-boolean(列表o1 2 o2)));2 = ac减法(推o1));; 默认:将原始令牌推送为未经验证的字符串(脏数据状态)(t(推tkn)))));;视觉反馈:回退到_G(Gouraud)以获得广泛的兼容性(vl-catch-all-apply 'vla-put-Direction(列表(vla-get-ActiveViewport doc)(vlax-3d-point 1 -1 1)))(vla-ZoomExtents(vlax-get-acad-object))(vl-catch-all-apply 'vl-cmdf(列表“_。阴影模式" "_G")));; --- 互动向导 ---(defun c:VAgent (/ dcl_tmp f dcl_id step res task v_l v_w v_h v_r prompt_data vcode_raw log_l log_r update-prompt build-stack)(setq dcl_tmp(vl-filename-mktemp“va_wizard.dcl”)f(打开dcl_tmp“w”));; 第1步用户界面(写行“va_step1:对话框{标签=\"V-Code形态矩阵模拟器\";宽度=85;"f)(写行“:文本{键=\"step_title\";字体=\"粗体\";对齐=居中;标签=\"步骤1:自然语言的模糊性\";}" f)(写线“:间隔{高度=0.5;}:boxed_radio_row {label=\"目标几何生成\";key=\"task\";" f)(写线“:无线电按钮{标签=\"实心盒\”;密钥=\"rb_盒子\";值=\"1\";}:无线电按钮{标签=\"实心球体\";键=\"rb_sph\";}:无线电按钮{标签=\"空心盒(布尔)\";键=\"rb_hol\";} }" f)(写线“:boxed_row { label=\"空间参数(可定制)\";" f)(写行“:编辑_框{标签=\"长度:\";键=\"v_l\";编辑_宽度=8;}:编辑_框{标签=\"宽度:\";键=\"v_w\";编辑_宽度=8;}" f)(写行“:编辑_框{标签=\"高度:\";密钥=\"v_h\";编辑_宽度=8;}:编辑_框{标签=\"半径:\";密钥=\"v_r\";编辑_宽度=8;是_启用=假;}}" f)(写字行“:boxed_column { label=\"Simulated LLM Prompt (Natural Language Payload)\"; : list_box { key=\"prompt_view\"; height=9; width=81; fixed_width=true; } }" f)(写行“:间隔{高度=0.2;}:行{间隔;:按钮{键=\"next\";标签=\"翻译成V-Code>\";is_default=true;宽度=24;}:按钮{键=\"取消\";标签=\"取消\";是_取消=真;宽度=14;} } }" f);; 第2步用户界面(写行“va_step2:对话框{标签=\“V-代码形态矩阵模拟器\”;宽度=75;”f)(写行“:文本{字体=\"粗体\";对齐=居中;标签=\"第2步:尺寸折叠(V-代码矩阵)\";}:间隔{高度=0.5;}" f)(写行“:boxed_column { label=\"宇宙语言(形态有效载荷)\”;:间隔{高度=1;}:文本{键=\"vcode_视图\";对齐=居中;字体=\"粗体\";}:间隔{高度=1;}}" f)(写线“:boxed_column { label=\"压缩指标\"; : text { label=\"> 需要程序自动LISP:~180个令牌\"; color=8; } : text { key=\"token_met\"; label=\"\"; } : text { label=\"> 空间幻觉风险:0%(严格类型铸造)\"; } }" f)(写线“:垫片{高度=0.2;}:行{:按钮{键=\"返回\";标签=\"<返回\";宽度=12;}间隔;:按钮{键=\"下一个\";标签=\"解析AST引擎>\";is_默认=true;宽度=24;}:按钮{键=\"取消\";标签=\"取消\";是_取消=真;宽度=12;} }}" f);; 第3步用户界面(写一行“va_step3 : dialog { label=\"V-Code形态矩阵模拟器\"; width=125;" f)(写行“:文本{字体=\"粗体\";对齐=居中;标签=\"第3步:基于堆栈的虚拟机执行\";}:间隔{高度=0.5;}" f)(写行“:行{:boxed_column{label=\"V-Code Stream\"; : list_box { key=\"log_l\"; height=12; width=28; fixed_width=true; } }" f)(写入行“:boxed_column { label=\"本地CAD引擎执行堆栈(反向抛光符号)\"; : list_box { key=\"log_r\"; height=12; width=88; fixed_width=true; } } }" f)(写线“:间隔{高度=0.2;}:行{:按钮{键=\"返回\";标签=\"<返回\";宽度=12;}间隔;:按钮{键=\"下一步\";标签=\"在CAD中执行几何\";is_默认=true;宽度=30;}:按钮{键=\"取消\";标签=\"取消\";is_取消=真;宽度=12;} }}" f)(关闭f);; 状态 Init(setq任务“rb_box”v_l“10”v_w“10”v_h“10”v_r“6”步骤1)(defun更新提示()(setq v_l(get_tile "v_l”) v_w(get_tile "v_w") v_h (get_tile "v_h") v_r (get_tile "v_r") 任务 (get_tile "task"))(控制((=任务“rb_box”)(mode_tile "v_l" 0) (mode_tile "v_w" 0) (mode_tile "v_h" 0) (mode_tile "v_r" 1)(setq prompt_data(列表“系统:钩入LLM上下文...”(strcat > 提示:\“创建一个实心框,测量“v_l”由“v_w”由“v_h”。\"") "" "> 操作:注入V-Code 256-Rune词典...”"> 注意:数字流必须通过解码符文\U+15B4解压缩。”">命令:将人类请求转换为形态矩阵。"))(setq vcode_raw(strcat v_l "," v_w "," v_h " \U+15B4 \U+1676")))((= 任务 "rb_sph")(mode_tile "v_l" 1) (mode_tile "v_w" 1) (mode_tile "v_h" 1) (mode_tile "v_r" 0)(setq prompt_data(列表“系统:连接到LLM上下文...”(strcat > 提示:\“创建一个半径为“v_r”的实体球体。\"") "" "> 操作:注入V-Code 256-Rune词典...”"> 注意:数字流必须通过解码符文\U+15B4解压缩。"))(setq vcode_raw(strcat v_r " \U+15B4 \U+167A”)))((=任务"rb_hol")(mode_tile "v_l" 0) (mode_tile "v_w" 0) (mode_tile "v_h" 0) (mode_tile "v_r" 0)(setq prompt_data(列表“系统:钩入LLM上下文...”(strcat >提示:\“创建一个“v_l“x”v_w“x”v_h“框,创建一个半径“v_r“球体,”)”并从框中减去球体。\" " "" "> 操作:注入V-Code词典...”"> 注意:原始文本流必须通过 \U+15B4 解码。"))(setq vcode_raw (strcat v_l "," v_w "," v_h " \U+15B4 \U+1676 " v_r " \U+15B4 \U+167A \U+15E3")))))(start_list“prompt_view”)(mapcar 'add_list prompt_data)(end_list))(defun构建堆栈()(控制((=任务“rb_box”)(setq log_l(列表(strcat v_l ",” v_w "," v_h) "\U+15B4" "\U+1676")log_r(列表(strcat "-> PUSH: \"" v_l "," v_w ", v_h "\" (Raw Stream)") "-> EVAL: \U+15B4 | Unpack Stream -> PUSH(3 Scalars)" "-> EVAL: \U+1676 (Rune 'Tot' / 3D BOX)" " | POP(3), Evaluate vla-addbox, PUSH(Ptr_Solid_A)”))))((= 任务 "rb_sph")(setq log_l(列表v_r "\U+15B4" "\U+167A")log_r (list (strcat "-> PUSH: \"" v_r "\" (Raw Stream)") "-> EVAL: \U+15B4 | Unpack Stream -> PUSH(1 Scalar)" "-> EVAL: \U+167A (Rune 'Kok' / SPHERE)" " | POP(1), Evaluate vla-addsphere, PUSH(Ptr_Solid_A)”))))((=任务"rb_hol")(setq log_l(列表(strcat v_l "," v_w "," v_h) "\U+15B4" "\U+1676" v_r "\U+15B4" "\U+167A" "\U+15E3")log_r (list (strcat "-> PUSH: \"" v_l ",," v_w ", v_h "\" (Raw Stream)") "-> EVAL: \U+15B4 | 解压缩流 -> PUSH(3 Scalars)" "-> EVAL: \U+1676 | Draw BOX -> PUSH(Ptr_Solid_A)") (strcat "-> PUSH: \"" v_r "(原始流)") "-> EVAL: \U+15B4 | 解压缩流 -> PUSH(1 Scalar)" "-> EVAL: \U+167A | Draw SPHERE -> PUSH(Ptr_Solid_B)"""-> EVAL: \U+15E3 | 减法 (A-B) -> PUSH(Ptr_Final)))))));;主事件循环(如果(>=(setq dcl_id(load_dialog dcl_tmp))0)(progn(而(和(>步骤0)(<=步骤3))(如果(new_dialog(strcat“va_step”(itoa step))dcl_id)(progn(控制((=第1步)(set_tile任务“1”)(set_tile“v_l”v_l)(set_tile“v_w”v_w)(set_tile“v_h”v_h)(set_tile“v_r”v_r)(更新提示)(action_tile“任务”“(更新提示)”)(action_tile "v_l" "(update-prompt)”) (action_tile "v_w" "(update-prompt)”)(action_tile "v_h" "(更新提示)”) (action_tile "v_r" "(更新提示)”)(action_tile“next”“(done_dialog 2)”))((=第2步)(set_tile“vcode_view”(strcat“[VCODE]“vcode_raw”[/VCODE]”))(set_tile "token_met" (strcat "> V-Code Matrix consumed: " (itoa (length (VA:Split vcode_raw " "))) " 令牌 (压缩:97.4%)))(action_tile“back”“(done_dialog 1)”)(action_tile“next”“(done_dialog 3)”))((=步骤3)(构建堆栈)(start_list“log_l”)(mapcar 'add_list log_l)(end_list)(start_list“log_r”)(mapcar“add_list log_r)(end_list)(action_tile“back”“(done_dialog 2)”)(action_tile“next”“(done_dialog 4)”)))(action_tile“取消”“(done_dialog 0)”)(setq res(start_dialog))(setq步骤(如果(>= res 0)res 0)))(setq步骤0)))(卸载_对话框dcl_id)))(vl-file-delete dcl_tmp)(如果(=步骤4)(progn(princ(strcat“\n[V-Code]接收到的原生有效负载:“vcode_raw))(princ “\n[V-Code] AST 崩溃到物理现实...”)(VA:RunVCode vcode_raw)(princ“\n[成功]空间执行完成。”)))(王子))(princ "\n[VedaCAD/v-code]沙盒已加载。输入VAGENT来启动模拟器。”)(王子) The above code can also be installed and used through VedaCAD developed by me via VCID: PLG96B (Support to receive version updates) The full 256 token V-Code is open-sourced on GitHub: https://github.com/VedaCAD/v-code Would love to hear your thoughts. Enjoy the sandbox! Note: English is not my native language. I use Google AI to translate and polish my posts to ensure clarity and respect for the community's technical depth. Edited 1 hour ago by VicoWang Quote
