I can't figure out how to add commands to the block editor ribbon in my CUI file, specifically, the Parameters Manager.
When I open my CUI and select my workspace there doesn't seem to be a ribbon section for the block editor, or at least I cannot find it. Can someone guide me to where it is please?
Is it something to do with it being hidden until the block editor is active?
Is this what your asking about?
AFAIK this is only a Contextual tab, it would be there when opening the Block Editor custom workspace or not.
All of my workspaces show an entry for the Ribbon tabs, but it only shows those regularly available, not any of the Contextual tabs, though LT may be limited in the CUI, I'm not sure.
You should be able to customize it... Help | About Customizing Ribbon Contextual Tab States | Autodesk
Yes, similar to what you've shown but I'm unable to drag them to the 'Workspace Contents' on the right side of the CUI where I thought there would be a ribbon panel for block editor commands (there isn't one).
I've found some block editor ribbon panels and dragged them across to my workspace but then these constantly show in the ribbon area and when I edit a block it adds a second. Now I have a conflict after closing the editor, the 'permanent' block editor ribbon panel is only showing the 'close block editor' command and when I click it I get a message saying it can only be used in the block editor.
What I want to do is add commands to the ribbon shown in the 2nd image below
Edited by SAFeSTeR
Did you check the link I posted on customizing the Contextual tabs?
You cannot add them to the Workspaces as they already activate when you open the block editor.
Ahhh, I didn't see the link, I'll check it out later.
Thanks, I'm sure it will help.
