I thought I might write some samples to help guide lisp users that are interested in trying out Python.
Long time lisp users will feel right at home using result buffers (DXF Lists). In PyRx, it’s wrappers around the old school C ADS functions, I.e. ads_entget, yay, like driving an F-150 with a toilet bowl plunger as the gear shift. In Python, most of these old functions reside in Db.Core
The resbuf* linked lists are wrapped into a list of tuples.. does this output look familiar?
from pyrx import Ap, Db, Ed, Ge
@Ap.Command()
def doit0() -> None:
    #entsel with a filter
    ps, id, _ = Ed.Editor.entSel("\nPick it: ", Db.Line.desc())
    if ps != Ed.PromptStatus.eOk:
        raise RuntimeError("oof {}:".format(ps))
    #get the result buffer
    rb = Db.Core.entGet(id)
    print(rb)
    # (-1, PyDb.ObjectId(1de8bf954d0)),
    # (0, 'LINE'),
    # (330, PyDb.ObjectId(1de8bf9a1f0)),
    # (5, '265'),
    # (100, 'AcDbEntity'),
    # (67, 0),
    # (410, 'Model'),
    # (8, '0'),
    # (100, 'AcDbLine'),
    # (10, PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)),
    # (11, PyGe.Point3d(100.00000000000000,100.00000000000000,0.00000000000000)),
    # (210, PyGe.Point3d(0.00000000000000,0.00000000000000,1.00000000000000))
In Python, there isn’t an assoc function, we can iterate through and search for a DXF code
@Ap.Command()
def doit1() -> None:
    # entsel with a filter
    # get the result buffer
    # 1. Analog to Lisp: (assoc 8 rb) -> Returns the full pair (8, "LayerName")
    dxf_code, value = next((item for item in rb if item[0] == 8), None)
    # 2. Extract just the value safely
    if dxf_code:
        print(f"The layer is: {value}")
In Python, tuples are immutable, so if we want to modify the list, you have to replace it. In this sample we modify the start and end of a line
@Ap.Command()
def doit3() -> None:
    # Loop through the result buffer list and modify matching DXF codes
    for i, item in enumerate(rb):
        dxf_code = item[0]
        if dxf_code == 10:
            rb[i] = (10, Ge.Point3d(0, 0, 0))
        elif dxf_code == 11:
            rb[i] = (11, Ge.Point3d(100, 100, 0))
    # Apply changes back to the AutoCAD database
    Db.Core.entMod(rb)
This might be better example, maybe similar to the COND expression?
@Ap.Command()
def doit4() -> None:
    # Process the result buffer using structural pattern matching
    updated_rb = []
    for item in rb:
        match item:
            case (10, _):
                updated_rb.append((10, Ge.Point3d(0, 0, 0)))
            case (11, _):
                updated_rb.append((11, Ge.Point3d(100, 100, 0)))
            case _:
                updated_rb.append(item)
    Db.Core.entMod(updated_rb)
And top it off with entMake
@Ap.Command()
def doit5() -> None:
    Db.Core.entMake([(0 , "LINE"),(10, Ge.Point3d(0, 0, 0)),(11, Ge.Point3d(100, 100, 0))])
Edited by Danielm103
