I thought I might write some samples to help guide lisp users that are interested in trying out Python.
Long time lisp users will feel right at home using result buffers (DXF Lists). In PyRx, it’s wrappers around the old school C ADS functions, I.e. ads_entget, yay, like driving an F-150 with a toilet bowl plunger as the gear shift. In Python, most of these old functions reside in Db.Core
The resbuf* linked lists are wrapped into a list of tuples.. does this output look familiar?
from pyrx import Ap, Db, Ed, Ge
@Ap.Command()
def doit0() -> None:
    #entsel with a filter
    ps, id, _ = Ed.Editor.entSel("\nPick it: ", Db.Line.desc())
    if ps != Ed.PromptStatus.eOk:
        raise RuntimeError("oof {}:".format(ps))
    #get the result buffer
    rb = Db.Core.entGet(id)
    print(rb)
    # (-1, PyDb.ObjectId(1de8bf954d0)),
    # (0, 'LINE'),
    # (330, PyDb.ObjectId(1de8bf9a1f0)),
    # (5, '265'),
    # (100, 'AcDbEntity'),
    # (67, 0),
    # (410, 'Model'),
    # (8, '0'),
    # (100, 'AcDbLine'),
    # (10, PyGe.Point3d(0.00000000000000,0.00000000000000,0.00000000000000)),
    # (11, PyGe.Point3d(100.00000000000000,100.00000000000000,0.00000000000000)),
    # (210, PyGe.Point3d(0.00000000000000,0.00000000000000,1.00000000000000))
  • Like 2
In Python, there isn’t an assoc function, we can iterate through and search for a DXF code
@Ap.Command()
def doit1() -> None:
    # entsel with a filter
    # get the result buffer
    # 1. Analog to Lisp: (assoc 8 rb) -> Returns the full pair (8, "LayerName")
    dxf_code, value = next((item for item in rb if item[0] == 8), None)
    # 2. Extract just the value safely
    if dxf_code:
        print(f"The layer is: {value}")
  • Like 2
In Python, tuples are immutable, so if we want to modify the list, you have to replace it. In this sample we modify the start and end of a line
@Ap.Command()
def doit3() -> None:
    # Loop through the result buffer list and modify matching DXF codes
    for i, item in enumerate(rb):
        dxf_code = item[0]
        if dxf_code == 10:
            rb[i] = (10, Ge.Point3d(0, 0, 0))
        elif dxf_code == 11:
            rb[i] = (11, Ge.Point3d(100, 100, 0))
    # Apply changes back to the AutoCAD database
    Db.Core.entMod(rb)
  • Like 2
This might be better example, maybe similar to the COND expression?
@Ap.Command()
def doit4() -> None:
    # Process the result buffer using structural pattern matching
    updated_rb = []
    for item in rb:
        match item:
            case (10, _):
                updated_rb.append((10, Ge.Point3d(0, 0, 0)))
            case (11, _):
                updated_rb.append((11, Ge.Point3d(100, 100, 0)))
            case _:
                updated_rb.append(item)
    Db.Core.entMod(updated_rb)
  • Like 2
And top it off with entMake
@Ap.Command()
def doit5() -> None:
    Db.Core.entMake([(0 , "LINE"),(10, Ge.Point3d(0, 0, 0)),(11, Ge.Point3d(100, 100, 0))])
Edited by Danielm103
  • Like 2
Daniel,
For total LISP hacks like me who barely get by piecing together LISP code that we find online. I don't even know where to begin with trying to utilize the awesome python code that you share.
It isn't as easy as opening Notepad and copying and pasting code and then saving as a different filetype. Then dragging that file into your drawing area to load and use. So I am asking as a total beginner, Where do I start? Is there a simple breakdown with instructions for us curious newbies?
Thanks
~Greg
BTW - Thanks for all the stuff that you share
@troggarf yep took the plunge and installed Python, the install is easy
With @Danielm103 help also installed a couple of extra modules that where needed for his code. Then it's simple like lisp using Pyload instead of Appload. Or you can load python scripts using a lisp call.
; lisp start python
(setq
    python "C:/Users/xxxxxx/AppData/Local/Python/Python-3.14-64/python.exe"
    pyscript "D:\\alan\\lisp\\ctb table.py"
(startapp python pyscript)
Edited by BIGAL
  • Like 3
6 hours ago, troggarf said:
Daniel,
VisualArt & Design
Thanks
~Greg
Start here https://github.com/CEXT-Dan/PyRx#python-for-autocad
1, watch the short YouTube video and download Python 3.14 from the link provided
2, download in install VS Code, install python extension pack
3, try out some of the samples, https://github.com/CEXT-Dan/PyRx/tree/main/PySamples
  • Thanks 1
I have a zero installer here, https://github.com/CEXT-Dan/PyRx-Redistributable I still need to update it to Python 3.14. so it not currently functional.
It’s based off the embedded package; the idea is if you have some cool libraries you want to share within an organization. It can be unzipped as an AutoCAD. Bundle. You can also roll your own with the embedded package https://www.python.org/downloads/windows/
If you want to run scripts outside of CAD, you’ll probably need the full install.
There are other people that use virtual environments and python managers like Anaconda. They know more than me with regards to setup  lol
For new people, I recommend to follow the instructions, watch the video
  • 3 weeks later...
YIL (yesterday I learned) there's a Python interpreter in ArcGIS. It's just a shell, but if you want to dip your toe in the water, it will let you run some code.
When I have some time, I'll take it for a spin and report back.
Guessing for Shapely, GeoPandas and other cool GIS tools.
Pathon work on dwg or dxf only?
Pathon a new programming language ? 🤣
Just open a dxf or a dwg can then run Python scripts. But must install the Python run time.
