indiancad Posted yesterday at 10:14 AM Posted yesterday at 10:14 AM I've been testing the same DWG files across different CAD applications and comparing how they handle layers, blocks, dimensions and XREFs. One interesting thing I've noticed is that DWG compatibility isn't just about opening the file—it also matters how accurately the drawing behaves when edited and saved. Has anyone here compared different DWG-compatible CAD applications on the same project files? "ACTCAD was one of the applications I tested." , and so far it has handled my DWG files quite well, including layers, blocks and XREFs. I’d be interested to hear if others have had similar or different experiences with ACTCAD or other DWG-compatible CAD software. Quote
Danielm103 Posted 1 hour ago Posted 1 hour ago If I’m not mistaken, ACTCAD uses ITC/ODA libraries. DWG compatibility should be good. Quote
SLW210 Posted 6 minutes ago Posted 6 minutes ago Once again please mention the ActCAD you used for the testing, it also wouldn't hurt to mention what CAD you compared. ActCAD is IntelliCAD based. Looks to be priced very nicely as well. Quote
