Azimuth and Distance with Drawn out Leaders Dimensioning on Civil 3D 2018
Dear All,
Excited to join this Forum.
I would appreciate guidance on how to achieve the below for a 147km Topographical Survey Project.
I want to Auto Annotate a polyline in civil 3d 2018 with Azimuth bearing showing only degrees and minutes and distance with a leader and arrow head pointing to each segments between points, but with the leader line drawn away from the line as shown on the attached image using civil 3d and i want azimuth and distance split into two stacked lines separated by a divider?
The process should be automatic when I click the Polyline, so i don't have to manually click each segment.
I have attached an image of what it should look like.
Your help is appreciated.
Thank You.
14:30
To achieve this automa
Post a sample dwg.
CIV3D has a lot of labelling stuff, usually though have to move the label when applied automatically, you may need a custom lisp.
There is maybe label Pline legs lisp out there but they would be parallel to each leg. Search Kent Cooper forums/autodesk pretty sure he has something.
You can create a label style that looks like what you want. You can use Annotation | Add Multipurpose Labels | Multiple Segment to create labels, all at once, for every segment of a polyline. How you drag them away from their segments, I don't know. Maybe isolate them and use the stretch command on a linear bunch at a time.
