indiancad Posted 2 hours ago Posted 2 hours ago Have you ever opened a DWG and suddenly thought, “Where did my drawing go?” The objects may still be there, but they could be far from the current view, on a turned-off layer, or hidden inside another location. Here are a few quick things I usually check: Zoom Extents to see if the drawing is just far away from the current view. Layer visibility (make sure layers are not frozen or turned off). Check if objects are on a hidden or locked layer. UCS / View settings in case the view is rotated or shifted. Drawing units & scale to ensure objects aren’t extremely small or large. Use SELECT ALL to confirm objects still exist in the file. I usually start with Zoom Extents first, then move through the rest. I usually start with Zoom Extents first, then move through the rest. What do you check first when your drawing suddenly disappears? Quote
