Have you ever opened a DWG and suddenly thought, “Where did my drawing go?”
The objects may still be there, but they could be far from the current view, on a turned-off layer, or hidden inside another location.
Here are a few quick things I usually check:
  • Zoom Extents to see if the drawing is just far away from the current view.
  • Layer visibility (make sure layers are not frozen or turned off).
  • Check if objects are on a hidden or locked layer.
  • UCS / View settings in case the view is rotated or shifted.
  • Drawing units & scale to ensure objects aren’t extremely small or large.
  • Use SELECT ALL to confirm objects still exist in the file.
  • I usually start with Zoom Extents first, then move through the rest.
What do you check first when your drawing suddenly disappears?
My $0.05.
ZOOM E
zoom c (getvar 'extmax) 100
May need a different scale than 100
If ok then
zoom c (getvar 'extmin) 100
  • 2 weeks later...
One other thing I've noticed.. Inserting a 3d block into model space. Occasionally everything in model space disappears and the 3d part appears, nothing else.
Purging does not solve it, the 3d part is invisible otherwise.
It's very strange and may be a bug in v10.
Do you have an example drawing that does this?
That sounds more like a Graphics Card or driver issue, though as you say, could be AutoCAD 2010 (I presume that's what you mean since v10 is very old now and was released in 1988).
If you still use v10 I would definitely say that's the issue.
