import wx
import random
from pyrx import Ap, Db, Ed, Gs
class TestDialog(wx.Dialog):
    def __init__(self, parent, size, pos):
        wx.Dialog.__init__(self)
        self.Create(parent, wx.ID_ANY, "", pos, size, style=wx.BORDER_NONE)
        self.width = size.GetWidth()
        self.height = size.GetHeight()
        self.static_bitmap = None
        self.image = None
        self.raw_data = None
        self.offsets = [0] * self.width
        self.bg_r = 0
        self.bg_g = 0
        self.bg_b = 0
        self.timer = wx.Timer(self)
        self.Bind(wx.EVT_TIMER, self.on_melt_tick, self.timer)
    def setImage(self, img: wx.Image):
        self.image = img
        self.raw_data = bytearray(self.image.GetData())
        if len(self.raw_data) >= 3:
            self.bg_r = self.raw_data[0]
            self.bg_g = self.raw_data[1]
            self.bg_b = self.raw_data[2]
        bmp = wx.Bitmap(self.image)
        if not self.static_bitmap:
            self.static_bitmap = wx.StaticBitmap(self, wx.ID_ANY, bmp, pos=(0, 0))
        else:
            self.static_bitmap.SetBitmap(bmp)
        self.static_bitmap.Bind(wx.EVT_LEFT_DOWN, self.on_click)
        self.timer.Start(33)
    def on_melt_tick(self, event):
        stride = self.width * 3
        melted_anything = False
        for x in range(self.width):
            if self.offsets[x] < self.height:
                increment = random.randint(2, 8)
                self.offsets[x] = min(self.height, self.offsets[x] + increment)
                melted_anything = True
            offset = self.offsets[x]
            if offset == 0:
                continue
            x_offset = x * 3
            for y in range(self.height - 1, offset - 1, -1):
                target_idx = (y * stride) + x_offset
                source_idx = ((y - offset) * stride) + x_offset
                self.raw_data[target_idx] = self.raw_data[source_idx]
                self.raw_data[target_idx + 1] = self.raw_data[source_idx + 1]
                self.raw_data[target_idx + 2] = self.raw_data[source_idx + 2]
            for y in range(offset):
                bg_idx = (y * stride) + x_offset
                self.raw_data[bg_idx] = self.bg_r
                self.raw_data[bg_idx + 1] = self.bg_g
                self.raw_data[bg_idx + 2] = self.bg_b
        if not melted_anything:
            self.timer.Stop()
            return
        self.image.SetData(bytes(self.raw_data))
        self.static_bitmap.SetBitmap(wx.Bitmap(self.image))
    def on_click(self, event):
        self.timer.Stop()
        self.EndModal(wx.ID_OK)
@Ap.Command()
def doit():
    doc = Ap.curDoc()
    db = doc.database()
    wxDoc: wx.Window = doc.getWxWindow()
    sz = wxDoc.GetSize()
    pos = wxDoc.GetScreenPosition()
    img: wx.Image = Gs.Core.getBlockImage(db.modelSpaceId(), sz.GetWidth(), sz.GetHeight(), 1.0)
    dlg = TestDialog(wxDoc, size=sz, pos=pos)
    dlg.setImage(img)
    dlg.ShowModal()
    dlg.Destroy()
Edited by Danielm103
