VicoWang Posted 56 minutes ago Posted 56 minutes ago (edited) This is a dimension marking tool for dense parallel line bundles, which can adjust the size of the marking through the G key during the preview process, and can be executed using the SD shortcut key (or one you customize). Installation method (upgradable in the future): [Side DIM] VCID: 5EDNWJ @ VedaCAD Note: To install via VCID, you need to install VedaCAD in advance and log in to a free account (or PRO account). Tips: Welcome developers to publish their plugins on VedaCAD and obtain their plugin's VCID for plugin sharing (even free accounts can publish) Edited 51 minutes ago by VicoWang Quote
