indiancad Posted August 31 Posted August 31 Have you ever used PEDIT → JOIN, but CAD does not join the lines? Sometimes the lines look connected, but there is a small gap between them. They can also have different Z values. First, check the endpoints using OSNAP. If the lines have different Z values, FLATTEN can help bring them to the same level. How many of you have faced this problem? What fixed it for you? Quote
SLW210 Posted August 31 Posted August 31 If you have an AutoCAD license, you get the toolsets like Map 3D free, you could use MAPCLEAN, which can fill gaps and also has a weed function and more. What if they are overlapping and not a gap, you can get unexpected results from a large selection set and MPedit>Join from overlapping/collinear (P)Lines? I use MPedit as well, you just have to run a polyline weed LISP (like PLDiet.lsp) sometimes to get single polylines. You may also want to look into Overkill and Fillet with radius = 0, it can help with cleanup as well. I know everyone that has this problem is working on a drawing that was not of their own and either generated by another CAD platform or by a past or former coworker. But, the best method for these issues are to properly use and setup your CAD not to have unjoined/unconnected/ends touching (P)Lines, Arcs, Splines, etc. Good post from @irneb here on that issue... Quote
imagetocad Posted September 3 Posted September 3 One additional thing worth checking is the join tolerance. Even when two endpoints appear connected on screen, there may still be a very small gap between them. For imported or automatically generated geometry, I normally use this cleanup sequence: Use FLATTEN to make sure all objects have the same Z value. Run OVERKILL to remove duplicate or overlapping segments. Use PEDIT → Multiple → Join, with a small fuzz distance. Check any remaining endpoints with DIST or the Properties panel. I would avoid using a large fuzz distance because it may join nearby objects that should remain separate. It is also worth checking whether some objects are splines or arcs rather than lines or polylines. With geometry converted from PDFs or raster images, duplicate short segments and tiny overlaps are often the real cause rather than a clearly visible gap. Quote
Paul Li Posted Monday at 06:35 PM Posted Monday at 06:35 PM I would first make sure they have the same elevation (z value). Then I would grip the end point of one of the lines and drag that grip point to the end point of the other line. Finally try Pedit again to join the two. Quote
SLW210 Posted Tuesday at 11:37 AM Posted Tuesday at 11:37 AM 16 hours ago, Paul Li said: I would first make sure they have the same elevation (z value). Then I would grip the end point of one of the lines and drag that grip point to the end point of the other line. Finally try Pedit again to join the two. That's too much work on a large drawing, if it needs to be on the same elevation, you can Z = 0 (or what ever elevation you want) them individually or the entire drawing. Quote
CyberAngel Posted Tuesday at 01:13 PM Posted Tuesday at 01:13 PM For some reason, a polyline that is not parallel to the XY plane is hard to flatten. It may have a large value for elevation. If you take the easy route and change the elevation to 0, it moves to somewhere you didn't expect. The only solution I know of is to explode it, flatten all the segments, and join them again. You may want to isolate the polyline before you do that, in case the segments land in a cluttered area, where they'll be hard to select. Not sure why this happens, maybe it wasn't created in the UCS. Quote
SLW210 Posted 50 minutes ago Posted 50 minutes ago Here are a few simple methods to flatten a drawing. How to flatten geometry in a drawing in AutoCAD Products The PDF option is one I tried back when I used a LISP to import vector PDFs as lines, etc. I have run across arcs, circles, etc. that were somehow drawn like that as well. I have found blocks to be the biggest issue to get flat, particularly the ones that you would rather not have to explode. There are a few LISPs, etc. around that can handle the different issues you might run across. Quote
