Discus84 Posted yesterday at 05:12 PM Posted yesterday at 05:12 PM Hi, I always annotate in model space-it complicates changes to the model as there is more objects to encapsulate in stretch frames. What is more effective - model or paperspace dimesioning -keeping annotations away from the model.? Quote
CyberAngel Posted 23 hours ago Posted 23 hours ago I've never dimensioned in paper space. Too many things to go wrong. Also dimensions are weird, it's like they wanted to please everybody but wound up disappointing everybody. Quote
Discus84 Posted 20 hours ago Author Posted 20 hours ago I used to only work in model space and I would never have switched possibly if not for the new office that uses paper space templates.. I see only one advantage of this : publishing automatically all selected pages at once vs plot windows from model space. Quote
Paul Li Posted 1 hour ago Posted 1 hour ago I would like to add another advantage of plotting in paper space is the ability to have multiple vports looking at the same area in the model but using different scales. Quote
Discus84 Posted 1 hour ago Author Posted 1 hour ago 15 minutes ago, Paul Li said: I would like to add another advantage of plotting in paper space is the ability to have multiple vports looking at the same area in the model but using different scales. The problem is scaling dimensions and hatches. I usually copy a detail into completely separate space to edit and dimension this detail in paper space. Unless I'm missing something here.. Quote
Paul Li Posted 51 minutes ago Posted 51 minutes ago 9 minutes ago, Discus84 said: The problem is scaling dimensions and hatches. I usually copy a detail into completely separate space to edit and dimension this detail in paper space. Unless I'm missing something here.. Perhaps consider annotative dimensions & hatches Quote
