indiancad Posted 8 hours ago Posted 8 hours ago (edited) Have you ever needed just one object from inside a block or XREF? Instead of opening or editing the source drawing, NCOPY lets you copy the required object directly into your current drawing. For example, if you only need a wall, line, or detail from an XREF, run NCOPY, select the object, and place the copy where you need it. It can save time when working with large drawings and XREFs. How many of you use NCOPY regularly? What other lesser-known command saves you time? Edited 7 hours ago by indiancad Quote
CyberAngel Posted 7 hours ago Posted 7 hours ago When that is what you need done, NCOPY is a wonderful tool. You don't have to worry about orientation or layers, you don't have to cut and paste from somewhere else, you just select the object(s) you want. I don't use it often, but when I do, it's a real time saver. It's been in AutoCAD since 2013, so there's no excuse not to know about it. 1 Quote
Paul Li Posted 1 hour ago Posted 1 hour ago Actually prior to NCOPY I used a lisp command called XCOPY that basically did similar operations. Also could someone explain to me what the difference is with NCOPY Settings set to Insert vs Bind. Irregardless of which setting the NCOPY object result is always a non-block object. Quote
