I recently worked on a project where every revision was saved as a completely separate DWG file.
After a few revisions, it became difficult to know which file was the latest one.
A simpler approach is to keep the working DWG as the main file and use DWGPROPS to record revision information such as the revision number, date, and description.
For issued drawings, I also keep a clear revision naming convention rather than relying only on the filename.
This makes it much easier to identify the current drawing and understand its history.
How do you normally manage DWG revisions on larger projects?
This is one of the knottiest issues in engineering work. What constitutes a full revision? When do you issue a partial revision, if you do at all? How do you track the changes? How do you roll them back if necessary? Worst of all, different shops use different criteria, and sometimes the same shop uses different criteria for different projects.
It seems like common sense, since storage is so cheap these days, to save a new copy of the drawing for each revision, and append the revision number to the file name. That way the old revisions are still available if you need to refer to them or send them to someone. Even better, keep the revisions in a subfolder so they don't clutter up the main project folder. And this should go without saying--keep current backups!
The current working file should have the project name (or whatever) with no revision number. Again, though, some shops will use different standards.
For smaller projects, there's no need to keep old revisions, especially if you've sent them out all along. You can go back to those emails for attached copies of old drawings.
As always, simpler is better. Make a plan and stick to it. Otherwise you're asking for trouble.
Like @CyberAngel, different places do it different.
My current work place, for the work I do, I keep all copies (even those I never released) on a personal (company) cloud drive, the latest revision is the one posted on the network, the drawing name includes the revision number at the end. In most cases, the relevant personnel are emailed that a new revision is out, since one or more of them would have requested a change. P&IDs we keep the old revisions in a separate folder on the network and sometimes the same for certain projects. For contractor drawings I also put old drawings in a folder and only leave the latest revisions on the network. For ongoing projects my boss usually keeps everything in a project folder and then at the end the "As Built" goes on the network, "As Built" as in I usually (or my boss/both of us and/or a relevant engineer) have to go double check everything.
Other places I have done them pretty much every method CyberAngel mentioned and probably more, as each company and even sometimes different divisions in a company wanted them done "their way".
Like others if a revision then a dwg was saved. We also saved a "AS Built" dwg, all our dwg's were recorded and could be looked up, we went back to 1999. They were saved as Tiffs later on as Pdf's. As we controlled the dwg's in regards to access by others, server locked, we made sure only the latest version was in the current working directory, we had a superseded directory. As part of document control a new project had specific directories premade.
