c:\program files (x86)\xdsoft\sys\xdrx.x64.25.arx cannot find a procedure that it needs.
Perhaps you should contact the 3rd party vendor where you install this program from to get the file?
I haven't seen the person that was posting here promoting that in a while, but you might try messaging them here or their website.
@XDSoft
if you're running Civil 3D 2019, then xdrx.x64.25.arx is not the correct version, it would be xdrx.x64.23.arx
Edited by Danielm103
then xdrx.x64.25.arx seems correct, it should match (substr (getvar "ACADVER") 1 2)
Did you try contacting XDSOFT?
Maybe provide more information.
What are you attempting to do that gives the error?
HOW?
I LOAD "XDRx.x64.25.arx" AND i get this error
Why would I contact them? They have a website are usually on at a few AutoCAD fora.
@XDCAD_net and @XDSoft should be the originators of that program.
In looking at your first post, I would believe a newer program to be in C:\Program Files\, not in C:\ Program Files(x86)\.
Here are installation instruction from the GitHub... xdcad · GitHub
Quote
XDrx-API
AutoCAD AutoLisp Secondary Development Function Library
1.Installation help:
Unzip the file to the specified directory
Depending on your AutoCAD version, the 32-bit version of AutoCAD corresponds to x86, and the 64-bit version of AutoCAD corresponds to x64. Find the corresponding ARX file For example: the corresponding arx file for AutoCAD 2025 is: xdrx.2025.x64.arx
Use the mouse to drag the file install.lsp to the ACAD window, Select the specified ARX file in the SYS directory, After confirmation, if prompted when loading, choose to load.
Finished. This process only needs to be performed once, and XDrx API will be automatically loaded when AUTOCAD is started later
