granat Posted Saturday at 02:43 PM Posted Saturday at 02:43 PM c:\program files (x86)\xdsoft\sys\xdrx.x64.25.arx cannot find a procedure that it needs. Quote
Paul Li Posted Saturday at 05:20 PM Posted Saturday at 05:20 PM Perhaps you should contact the 3rd party vendor where you install this program from to get the file? Quote
SLW210 Posted Sunday at 11:19 AM Posted Sunday at 11:19 AM I haven't seen the person that was posting here promoting that in a while, but you might try messaging them here or their website. @XDSoft Quote
Danielm103 Posted Sunday at 01:25 PM Posted Sunday at 01:25 PM (edited) if you're running Civil 3D 2019, then xdrx.x64.25.arx is not the correct version, it would be xdrx.x64.23.arx Edited Sunday at 01:26 PM by Danielm103 1 Quote
Danielm103 Posted 23 hours ago Posted 23 hours ago then xdrx.x64.25.arx seems correct, it should match (substr (getvar "ACADVER") 1 2) Quote
SLW210 Posted 1 hour ago Posted 1 hour ago Did you try contacting XDSOFT? Maybe provide more information. What are you attempting to do that gives the error? Quote
granat Posted 1 hour ago Author Posted 1 hour ago Did you try contacting XDSOFT? HOW? I LOAD "XDRx.x64.25.arx" AND i get this error Quote
SLW210 Posted 43 minutes ago Posted 43 minutes ago Why would I contact them? They have a website are usually on at a few AutoCAD fora. @XDCAD_net and @XDSoft should be the originators of that program. In looking at your first post, I would believe a newer program to be in C:\Program Files\, not in C:\ Program Files(x86)\. Here are installation instruction from the GitHub... xdcad · GitHub Quote XDrx-API AutoCAD AutoLisp Secondary Development Function Library 1.Installation help: =================================================== Unzip the file to the specified directory Depending on your AutoCAD version, the 32-bit version of AutoCAD corresponds to x86, and the 64-bit version of AutoCAD corresponds to x64. Find the corresponding ARX file For example: the corresponding arx file for AutoCAD 2025 is: xdrx.2025.x64.arx Use the mouse to drag the file install.lsp to the ACAD window, Select the specified ARX file in the SYS directory, After confirmation, if prompted when loading, choose to load. Finished. This process only needs to be performed once, and XDrx API will be automatically loaded when AUTOCAD is started later Quote
