Paul Li Posted 19 hours ago Posted 19 hours ago Attached is an improved version of getfiled that implements powershell with the option to select single or multiple files returning a list of the selected item(s): Examples: (pl:getfiledps "Select Files" (getvar"dwgprefix") "dwg" 0) ; for single selection of file type dwg (pl:getfiledps "Select Files" (strcat (getenv "userprofile") "\\downloads") "dwg;dxf" 1) ; for multiple selection of file types dwg & dxf Feedback & comments are welcome. pl_getfiledps.lsp 3 Quote
SLW210 Posted 1 hour ago Posted 1 hour ago Many work computers are likely limited for using Powershell. Unrelated to Powershell being blocked, I get an error loading. error: string too long on input Quote
Steven P Posted 42 minutes ago Posted 42 minutes ago String too long - just a guess, file path and file name string length? - going back old school when we had 256? characters for it all - but just a guess Quote
SLW210 Posted 20 minutes ago Posted 20 minutes ago I'm not going to troubleshoot it since Powershell is blocked at work, but if the load has that error, then it's something in the Code, probable in the DCL write-line part. Quote
