GGuzzler Posted September 22 Posted September 22 Hi all, Having an issue that started recently where text pasted in from MS word looks fine in Paper space but then once printed to PDF, formats strangely. Please see screenshots attached. Any ideas much appreciated! vCT P2v0.1 YOC.dwg TEST.pdf Quote
SLW210 Posted September 22 Posted September 22 What does a Print Preview look like and one printed to paper look like? What are you using to plot to PDF? Computer Specifications? No issues here on Pdf. vCT P2v0.1 YOC-P2 no AA.pdf vCT P2v0.1 YOC-P2 no AA-2.pdf Quote
GGuzzler Posted September 22 Author Posted September 22 39 minutes ago, SLW210 said: What does a Print Preview look like and one printed to paper look like? What are you using to plot to PDF? Computer Specifications? No issues here on Pdf. vCT P2v0.1 YOC-P2 no AA.pdf 185.4 kB · 1 download vCT P2v0.1 YOC-P2 no AA-2.pdf 428.24 kB · 0 downloads Lenovo Yoga laptop, will check specs later. Print preview looks normal, then printing via DWG to PDF.pc3 causes the issue. Have tried reinstalling using pc3 in UserDataCache but without any change to result. Lato Regular is the font where I have the issue. Annoyingly this problem has only just started happening within the last couple of months. Quote
SLW210 Posted 2 hours ago Posted 2 hours ago What do your PDF options look like? What do your plot settings look like? Windows version? Are you using AutoCAD LT 2014? Quote
GGuzzler Posted 2 hours ago Author Posted 2 hours ago PDF options: please see snapshot. Windows 11 Home - 10.0.26200 Nope, AutoCAD LT 2025. Quote
Paul Li Posted 48 minutes ago Posted 48 minutes ago Do you have the latest LT 2025 updates installed? Enter About command, do a screenshot and share this here Quote
GGuzzler Posted 47 minutes ago Author Posted 47 minutes ago Just now, Paul Li said: Do you have the latest LT 2025 updates installed? Enter About command, do a screenshot and share this here Quote
Paul Li Posted 34 minutes ago Posted 34 minutes ago Since you do have the latest updates installed, here are some additional questions: 1) Any difference if the text is in model? 2) Does the same problem occur if you created the text using Lato Regular in LT and not copied it from Word? 3) What happens when you change the pasted text to Arial ttf or to Romans shx? 4) Have you tried installing LT 2026 side by side without migrating settings from LT 2025 to see if the same problem still occurs? Quote
