If you use notepad+ as an editor for Autolisp, the CTRL+ALT+b leaves a lot to be desired when it comes to selecting between brackets.
The VLIDE double-click is much more satisfying.
So here is an AutoHotKey script that gives you  this functionnality while preserving the normal Dbl-Click of notepad+:
#Requires AutoHotkey v2.0
#SingleInstance Off
; 1. Set up a unique communication highway (MsgNumber 0x401)
OnMessage(0x401, ReceiveCloseSignal)
ReceiveCloseSignal(wParam, lParam, msg, hwnd) {
    ExitApp
; 2. Find any running old instance (ignoring itself) and send it the "Self-Destruct" signal
DetectHiddenWindows True
if (oldScriptHwnd := WinExist(A_ScriptFullPath " ahk_class AutoHotkey")) {
    if (oldScriptHwnd != A_ScriptHwnd) { ; Ensure the script doesn't close itself!
        PostMessage(0x401, 0, 0, , "ahk_id " oldScriptHwnd)
        WinWaitClose("ahk_id " oldScriptHwnd, , 2)
; 3. Automatically relaunch the script using UI Access to bypass UAC entirely
if !A_IsCompiled && !InStr(A_AhkPath, "_UIA.exe") {
    uiaPath := RegExReplace(A_AhkPath, "\.exe$", "_UIA.exe")
    if FileExist(uiaPath) {
        try {
            Run('"' uiaPath '" "' A_ScriptFullPath '"')
            ExitApp
; 4. Your Application-Specific Hotkeys
#HotIf WinActive("ahk_class Notepad++")
~LButton:: {
    static lastClick := 0
    currentClick := A_TickCount
    if (currentClick - lastClick < DllCall("GetDoubleClickTime")) {
        KeyWait("LButton")
        Sleep(60)
        SendEvent("^!b")
        lastClick := 0
    } else {
        lastClick := currentClick
#HotIf
Link to download AutoHotKey https://www.autohotkey.com  also available on Microsoft app store (Free)
NppBrackets.ahk
I use this in visual studio to toggle between header and source. also since I'm a southpaw, I use home and end for copy paste
autohotkey is the GOAT!
#z::Run www.autohotkey.com
;ALT + XX
home::send ^c ;
end::send ^v ;
#IfWinActive ahk_exe devenv.exe
;PgUp::SendRaw `,DS.ARGS() ;misc command
;PgDn::SendRaw `,DS.ARGS({"val:type"}) ;misc command
Insert::send ^k^o ;toggle header/source
Delete::send ^a^k^f{Esc} ;select all and format
#IfWinActive
  • Like 2
  • Funny 1
Never thought about that - I always still use ctrl+ V / C - means I have to let go of the mouse every now and then
FYI: When running VS Code to select everything including the parenthesis,
When near the beginning of the code:
Click position right in front of the open parenthesis, then hit the following keyboard combinations Shift+Ctrl+Alt then Down Arrow
When near the end of the code:
Click position right after the close parenthesis, then hit the following keyboard combinations Shift+Ctrl+Alt then Up Arrow
Hi Paul,
When a keyboard shortcut requires 4 keys, I'm not so sure we should consider it a shortcut anymore.
Thanks, for the info nonetheless.
ymg
Edited by ymg3
typo
