Hi,
I am struggling to make this parametric template work.
It is always 1 constrain short of making it behave properly.
F.ex. in the curent hair pull-off session I can't make the crossed lines stay parallel/ horizontal, the mitre angle lock at 45 degree, the parallel tilted blue lines stay equal or whatever needed to prevent skewing.
Somehow I made 1 face and 2 face panel template work properly (it allready was a pain to make the two face and I dont know how I made it work)
But I need also 3, 4, 5 face panels, also a corner panel.
The problems come when I try to control the innermost side flanges (where the 45 degree miters are).
If they are not equal,the sketch skews, but they might not be equal in some occasions.
What is the correct order of applying dimensions and constrains?
I know the geometry I am trying to force is completely legit (I can draw it manualy) but that is not the point, it is extremely tedious and boring when a lot of panels need to be done.
Can I find ready parametric templates for this?
The constraints interaction seems to make the task impossible.
Regards - Emil
Welcome to CADTutor!
Can you post a .dwg?
Hi, the 1 and 2 face templates work.
The 3 face templates are squared in yellow, one is parametric sketch, the other is a dynamic block, completely messed up now.
Seems easier to apply strech action in a dynamic block but I still have to apply TONS of constraints (coincident points, parallel...)
I understood I can mass apply them with AUTOCONSTRAIN, but still needs a lot of adjustment and clean up.
At least didn't reach the "overconstrained" warining within a dynamic block.
PARAMETRIC.dwg
Made parametric sketches and blocks for 1, 2, 3 face panels.
Parametric definitions appear as block properties and could be set there along with label tags (detail name and pieces).
I spent the whole morning (setting the correct order of constraints) and I didnt come to a clear order how to do that.
Autoconstrain does not take into account the constraintsettings dialog.
- f.ex. I started mass applying 'coincident'. It applied a lot of other constraints, then I deleted them.
- second (if I remember properly) I applied the 45 degree miter locks
- then I started moving the inner most flanges (along the miters) with a strech command to see what is going on.
- then I applied collinear to all simultaneously moving vertical lines.
- then I applied parallel to lock them parallel
- added here and there some perpendicular
- finally I added horizontal constraint to the bottom horizontal line
(now I have to make a new sketch/ block for the same panels if they are rotated 90 degree)
- finally finnaly some extra constraints here and there after testing....
I HOPE IT WONT BREAK, but I am gonna need another free half a day to make 4, 5 face and corner templates....
PARAMETRIC.dwg
Again no problems drawing what you want can be multiple panels with options but will be p/line objects, some blocks, dimensions and so on, just not one complete block. Can embed details of the panels as say Xdata can then extract that data into a BOQ. The only real limit in number of panel details is the size of the pc screen, it limits to about 20 lines. Can just auto fill a panel details and for each new panel just change say required values. So say witdth would be the same every time auto filled. Could do a Equal option for number of panels so only fill in one panel sizes. Did notice the little side line work yes can be included.
Did you look at movie ?
It is a small production work, no BOQ needed. The "work order" comes as hand sketches, all sizes for the aluminum panels facade are taken on site.
The panel's dwg go straight to cam software for nesting and CNC router output (the green line is perimeter cutting, beter to be closed polyline).
Made something like "parametric blocks", the adjustable dimensions appear as properties and could be set directly there (image and dwg attached).
One extra step could be - when there is just one side flange, the V groove (the blue line) overlaps with the perimeter cutting - this is extra milling time and not needed.
Set it as flange2 = 0 (Left, Right, Bottom, Top).
But as far as I get it I cannot make expression: (if flange2 = 0 -> the blue line to be hidden), so some manual cleanup is needed.
Then if flange2 is 0 the sketch might get buggy and not accept another dimension properly, so have to start over with fresh block or try to pull the dimension handles.
Parametric sketches work outside of a block - wrapping them into block is handy to set the dimensions as custom properties.
The constraint order is rougly:
- make all coincident points to rig the green (cutting) to the blue (V groove)
- delete ALL other constraints. Autoconstraint DOES NOT take into account what you set in 'constraintsettings' and the other constraints might overconstrain what u want to achieve.
- set fixed constraint (lower left corner)
- set lower left lines: along X - horizontal, along Y - vertical
- set colinear all vertical/ horizontal lines that are to be colinear.
- set the first colinear line parallel to the allready set horizontal/ vertical, these could be chain set (left to right, bottom to top)
- set the mitre angles locked at 45 (all of them)
- apply parametric dimensions (base dimensions, flanges in order inside out)
Setting parallel makes irregular (slightly trapezoid and slanted) panels imposible.
But a template for this IS near impossible. The proper 90 angles could be anywhere, so better manually explode and adjust with strech command>
Slanted/ irregular panels come usually as end rows/ columns of the mounting work, following the construction
- it is all cast in situ concrete and (kind of sloppy) masonry in between.
The block work:
- select all and make block, set basepoint matching with the fixed constraint.
- convert parametric dimensions to dynamic ones (inside block editor/ block edit tab/ tool for this)
- rename the dimensions to something usefull (in the object properties panel)
- set order/ priority in the 'parameters' dialog, so that the custom properties appear in an uniform order.
PARAMETRIC.dwg
Edited by emosms
I would avoid setting each flange. Begin with the panel dimensions then add horizontal, vertical, parallel and 45‑degree constraints only where the shape needs them. Measure each flange length on its own if the lengths can change. Look at the remaining degrees of freedom before adding another restriction because a missing restriction may control rotation or skew of length. Which CAD software are you using?
In the draw window it's for multi story buildings so size can be different for every window.
There is not a problem matching properties with a dcl. You can make better descriptions, in the code is default values you set or it can remember previous values. Just have the tools to make the dcl.
If you look at the window DCL in movie on right side is edge controls these do just that a corner or a multi panel join and so on. So in your comments you talk a bit about this. Yes it's drawn via objects Plines etc. You can have shapes like the V notch. The dimensioning is just part of a program. I believe it will be easier than trying to make a dynamic block work.
Given how much post time has occurred in this forum, a program would be done by now. But it is for your company only so a cost may be relevant. But you can add more shapes quickly. Will see if can find time to do some form of example.
Step 1
Edited by BIGAL
Step 1
dont quite get what u do (also the video above).
Is that Bricks Cad and DCL (data control language) used in bricks cad?
Edited by emosms
